Author Topic: My stainless steel DIY towfish.  (Read 20516 times)
Offline Mappe
  • Unit(s): 898c SI
  • Software: v6.420
  • Accessories: Towfish + 30m cable
« on: October 13, 2012, 03:23:01 AM »
My first home made towfish. Because im a sheet metal man, the only opinion was to build it from stainless steel. It weight 5,1 kilos. The pipe is 76mm and fins are laser cutted and TIG welded. Towfish head i turned from stainless steel. Cable is CAT6 and it goes inisde a rope.
Towfish, cable and unit.
Towfish
Sukellustyö Takala. Diving and geophysical survey service at Vaasa Finland.
Offline Rüdiger
Re: My stainless steel DIY towfish.
« Reply #1 on: October 13, 2012, 08:08:03 AM »
Hello Neighbour
Congratulations. successful work. :)
Interesting is the cable routing over the nose of the fish.
How long is the pull cable and is it  patch-or installation cable?
mvh
Rüdiger
Finding is better than losing
Offline Roddy
  • Scan,scan and rescan
« Reply #2 on: October 13, 2012, 01:19:22 PM »
Mappe, Nice clean build! Very well done! Lets have some screen shots.
Roddy
Scan,Scan and Rescan Roddy
Offline Mappe
  • Unit(s): 898c SI
  • Software: v6.420
« Reply #3 on: October 13, 2012, 03:27:28 PM »
Hello Neighbour
mvh
Rüdiger
Tack  Granne!
Cable is 28 meters long and its a CAT6 patch cable made for 500Mhz. It should be enough. I will post screenshots as soon as possible!
Offline Rickard
« Reply #4 on: October 13, 2012, 04:49:51 PM »
Mappe,
nice fish! Please test it before the winter season and show us! Your neighbors expect snow within a week.. ;)
Rickard
Offline Mappe
  • Unit(s): 898c SI
  • Software: v6.420
« Reply #5 on: October 14, 2012, 10:13:25 AM »
First test drive with my towfish! The cable is actually 33m long. Towfish was 5-7m down from sea level when i scanned. Here are the screenshots. All taken 455khz.
Rocks... wondering why is temperature so high in this screen?
Sunken wood boat.
Sunken wood boat. (zoom)
Offline Roddy
« Reply #6 on: October 14, 2012, 12:59:13 PM »
BINGO!!
Roddy
Offline Rüdiger
« Reply #7 on: October 15, 2012, 03:22:00 AM »
Hi Mappe
Good pictures and that with the 455khz. :)
Update your unit, then you have the whole screen for the important things, without data window on the left side.
mvh
Rüdiger
Offline Mappe
  • Unit(s): 898c SI
  • Software: v6.420
« Reply #8 on: October 15, 2012, 03:33:22 AM »
Hi Mappe
mvh
Rüdiger
Tackar!
How is the update made. Can you give me an easy instruction how to update my 898c si software? Thank you!
Offline Rüdiger
« Reply #9 on: October 15, 2012, 04:23:43 AM »
Hi Mappe
Register your unit at HB support, then you get access to the latest firmware.
http://www.humminbird.com/Support/
Even here in the forum, you can download the latest firmware.
http://forums.sideimagingsoft.com/index.php?action=downloads;cat=20
Save the download to an SD card and put them into your unit. The new firmware is automatically detected and after two confirmation installed.
Attention! Concern for a stable power supply, a crash during the update is to be avoided at all costs.
mvh
Rüdiger
Offline Mappe
  • Unit(s): 898c SI
  • Software: v6.420
« Reply #10 on: October 16, 2012, 05:50:57 AM »
Hi Mappe
mvh
Rüdiger
I updated my firmware to v6.420 successfull.
Thanks for the instruction!
Offline Kimi
  • Unit(s): 798CXI 898 CXI
« Reply #11 on: December 18, 2012, 03:38:45 PM »
Nice fish. Simple and beautiful.
One possibility is that seawater has come in contact whit the temperature sensor? The transducer is not built for highpressure in deepwater.
What happend after this "dive". Did the temp.readings go back to "normal"?
It can also has something to do whit the cable. (leaks, length?)
Greattings from south, terveisin etelästä. Kimi..
homepage: ( in Finish only) www.wreckdiving.yolasite.com
Offline Rüdiger
« Reply #12 on: December 19, 2012, 04:57:50 AM »
Hi neighbor ;)
This forum has already been reported that the cable inlet into the transducer is not pressurewater tight. >:(
Most resins shrink during curing and so the smallest leaks can arise.
mvh
Rüdiger
Offline Mappe
  • Unit(s): 898c SI
  • Software: v6.420
« Reply #13 on: December 22, 2012, 07:28:34 AM »
Hi neighbor ;)
mvh
Rüdiger
Tjena!
Thanks for the information. Ive allready sealed the cable inlet with a lot of sikaflex. :) I think it will work just fine!
Mappe
Offline abraquelebout
« Reply #14 on: December 22, 2012, 10:52:17 AM »
hi
if the water came into the cable you must have this pictureila_rendered
lot of gosht and noise, i want to find the best solution,  connecting box full of resins ?
Offline Kimi
« Reply #15 on: December 22, 2012, 12:15:36 PM »
if the water came into the cable you must have this picture lot of ghost and noise,
This is of course one possibility. But I think that the main reason of "ghostechoes" is that if the transducer got a clear and loud signal from one direction , but nothing from the opposite direction, it will "hear" the same returnsignal with the both piazoelements. Its good to remember that we are talking about a acoustic signal. The piezoelement does not understand from what direction the sound is coming.
An other thing that would be interesting to know and understand is what is really happening in a towfisch. Especially if it is made of metal.
Does the body(metaltube) collect the signal or and reflect it back. And what are the fins doing? Are they acting as somekinds of acoustic reflectors.
I have several times seen that the picture quality varies from good to poor, when I have using my own towfish. Towing the same route and same depth. So I guess that there is something happening down there that I don't understand. Maybe the fish i shaking, or maybe there are some acoustic resonance in the fish body?
Do someone got any ideas??
Kimi..
« Reply #16 on: December 22, 2012, 01:49:40 PM »
for my experience , it's the second gosht sequence i see, in the 2  when i cut the cable, the salt water make Electrolysis in some wire and ground, verry bad !!
for steel or metal remember what append to Jolly Roger :
http://forums.sideimagingsoft.com/index.php?topic=1753.0
Offline Mappe
  • Unit(s): 898c SI
  • Software: v6.420
« Reply #17 on: December 22, 2012, 05:10:01 PM »
Towfish has worked just fine and the information on screen is correct.
Greetings from Vaasa... Ice 30cm at sea and very cold.
Terveiset Vaasasta... Jäätä 30cm ja pirun kylmä.
Offline Rüdiger
« Reply #18 on: December 23, 2012, 04:36:11 AM »
Hi Kimi
Could be that the water temperature has influence on acoustic reflections, and thus the image quality.
mvh
Rüdiger
Last post February 24, 2010, 05:11:58 PM
Towfish
Started by keizerh keizerh
Last post September 15, 2009, 04:42:33 PM
by keizerh
Last post September 18, 2012, 04:09:03 AM
by Rüdiger
Last post April 30, 2010, 01:45:33 PM
Last post January 18, 2011, 05:39:12 PM
by abraquelebout
Last post October 29, 2011, 06:05:11 PM
by nediver
Last post November 07, 2011, 05:22:44 AM
Last post July 13, 2013, 06:51:56 AM
