Author Topic: GPS Ready ???  (Read 9214 times)
Offline joeyd50
  • Unit(s): 787c2
GPS Ready ???
« on: September 04, 2012, 04:27:24 PM »
I have a Humminbird 747c, it says GPS ready, what do I need to get the GPS working?
  Joe
Offline George
  • Software: Always up todate
Re: GPS Ready ???
« Reply #1 on: September 04, 2012, 06:58:31 PM »
joeyd50
It appears that all you need to do is plug in an AS GR16 GPS module.  This one has the 747c listed as working with the 747c model.  The AS GR50 does not list your model.
Not sure what you are going to see, it does not appear that there are any electronic maps associated with this system.  The manual does not have anything from what I can see that shows using the GPS, there should be something available.  Maybe Greg can help.
George
« Last Edit: September 04, 2012, 07:09:57 PM by George »
Offline joeyd50
  • Unit(s): 787c2
Re: GPS Ready ???
« Reply #2 on: September 04, 2012, 07:28:44 PM »
I didn't see anything in the manual, and looking at Humminbird website the antenna seems to be the only thing you need. I did that and nothing happened. I know the antenna is working because I plugged my son's 595c in and it worked fine.
Joe
Re: GPS Ready ???
« Reply #3 on: September 05, 2012, 02:46:23 PM »
Adding a GPS Receiver to the 747c unit will make it a trackplotter (no maps) type unit.  If the GR16 worked with the 595c unit than it should have also worked with the 747c.  Sounds like something is not working in the 747c unit.
Offline joeyd50
  • Unit(s): 787c2
Re: GPS Ready ???
« Reply #4 on: September 05, 2012, 03:35:46 PM »
Yea that's what I was thinking, I did know it was without maps, but it would still get me back where I started.
  Joe
Last post May 12, 2010, 08:27:55 PM
by calli1
Last post March 06, 2011, 08:19:59 AM
by Peter
Last post November 16, 2011, 10:32:14 PM
by Duckter
Last post February 05, 2014, 12:52:35 AM
by trentbosse
Last post March 24, 2015, 12:02:01 PM
by coy
Last post August 20, 2015, 11:18:01 PM
