Author Topic: power supply  (Read 14323 times)
Offline goodwinexplorer
  • Unit(s): 1187, 1198,c si combo
  • Software: 4.18
power supply
« on: August 29, 2012, 07:14:51 AM »
i run my unit via a 24 volt to 12 volts convert running at 12.5 volts, i have another unit running at 13.8 volts dc will the unit work any better as it is using less current if i use the higher voltage
has any one seen any difference?
bob
Re: power supply
« Reply #1 on: August 29, 2012, 07:48:42 AM »
As long as the unit has 10.5 volts, it should work well.
You have to be careful about putting too much voltage
through a unit, or you will fry it.  There is a limit, but I'm
not sure what it is.  A normal 12 volt battery will be fully
charged at about 12.5 volts.  These units were designed
to work with 12 volt battery systems. 13.8 volts seems
a bit high to me.
After having at least 10.5 volts, the other main thing is
having sufficient enough battery amperage to sustain
the unit.
It would be better to have a huge amp hour battery running with
at least 10.5 volts, than having a tiny amp hour battery running with
higher voltage.  The smaller battery will crap out a lot sooner.
And once the smaller battery starts to get weak, the voltage
will start to drop.
« Last Edit: August 29, 2012, 07:54:15 AM by ITGEEK »
Offline Jim Jack
  • My electronics cost more than my BMT
  • Unit(s): 998
  • Accessories: AS-WX1, AS GPS-HS
Re: power supply
« Reply #2 on: August 29, 2012, 09:46:11 AM »
"i have another unit running at 13.8 volts dc will the unit work any better as it is using less current if i use the higher voltage".
NO.
HB's will run on 10-20V DC input voltage.
Below 10V the power circuit can not convert/condition the input V to reliably run the unit. To get perfect straight line dc voltage the basic min rule of thumb is 2:1, 10V in 5V out. Above 20V the power circuit can not reliably clip the voltage to protect the unit from damage. This is why the units turn themselves off in either of those conditions.
Re: power supply
« Reply #3 on: August 29, 2012, 06:16:31 PM »
NO.
+1
The 13.8 V supply will make you less susceptible to voltage drop through your cable.....You will have more "breathing" room.
Offline George
  • Software: Always up todate
Re: power supply
« Reply #4 on: August 30, 2012, 08:44:15 AM »
I am not sure but believe I have read something on this site a long time ago that states that you must also have low amps.  There should be something on this site that gives the parameters of the converter requirements.  Do be careful so that you do not fry your system.
Offline gros21
  • Unit(s): 1197
  • Software: latest
Re: power supply
« Reply #5 on: October 05, 2012, 02:50:18 AM »
As a lecky.
the unit will have its own onboard voltage regulator taht will take voltage from 10-20vdc and convert it to a clea 5vdc and 12vdc or what eve rit needs. kind of like a PC.
yes in theory u could get volatge drop but i have measured my 1198c at full brightness and every thing running at 2.2A voltage drop will no be an isssue at all.
13.8vdc or 12.5v is ideal.
to be honest at home when playing with unit i run it of an old laptop PSU it runs at 18.7V still no issues, yes its close to teh limit but then again a laptop has a very clean power supply.
  • Software: 4.18
Re: power supply
« Reply #6 on: October 05, 2012, 04:52:05 AM »
thanks
Last post September 11, 2012, 03:11:45 AM
by gros21
Last post July 01, 2012, 03:18:34 PM
Last post February 24, 2013, 08:25:02 AM
by mulliemark
Last post September 03, 2013, 12:06:30 PM
Last post May 13, 2014, 09:51:45 AM
Last post December 24, 2014, 03:57:09 PM
Last post February 27, 2015, 03:53:25 PM
Last post April 30, 2015, 12:58:54 PM
by EZM
