Author Topic: Humminbird 595c?  (Read 12788 times)
Offline joeyd50
  • Unit(s): 787c2
Humminbird 595c?
« on: August 12, 2012, 12:08:28 PM »
Does anyone know what GPS antenna a Humminbird 595c takes? I looked eveywhere and I can't fine it.
  Joe
Re: Humminbird 595c?
« Reply #1 on: August 13, 2012, 01:34:59 PM »
I searched, and I could not find this information either.
When in doubt, get it straight from the horses mouth:
Humminbird Customer Service:1-800-633-1468
Offline navionic
« Reply #2 on: August 13, 2012, 02:33:29 PM »
  Joe
Yes. External.
« Reply #3 on: August 13, 2012, 02:42:22 PM »
The most uptodate antenna is the GR-50.
However if you are good with wires you can make most antennas fit your unit since it is external mount...
Offline navionic
« Reply #4 on: August 13, 2012, 03:08:27 PM »
GR 50 does not work with Fishfinder 595c
A very old machine. Only GR-16
« Reply #5 on: August 13, 2012, 05:22:14 PM »
Yes. External.
You might have added the older model and the gr16 as you just did.....so the rest of us would not stick our foot in our mouths..
Offline joeyd50
  • Unit(s): 787c2
« Reply #6 on: August 13, 2012, 05:37:32 PM »
It is the GR 16, the same one my 787c2 takes and my sons 595 works with mu antenna, so there is something wrong with the GPS in my unit.
  Joe
« Reply #7 on: August 13, 2012, 06:08:46 PM »
Joey, did not see that you had a problem, just the question..
Before you send to HB check the pins on the unit where the cable plugs in.
If they are ok then its off to HB for repair..
Offline navionic
« Reply #8 on: August 14, 2012, 04:30:54 AM »
  Joe
Try to reset the device and update firmware.
Offline joeyd50
  • Unit(s): 787c2
« Reply #9 on: August 14, 2012, 04:32:10 PM »
I reset Defaults and updated the software to the current software, it didn't help, is firmware something else I can update?
Joe
Offline navionic
« Reply #10 on: August 15, 2012, 02:18:43 AM »
Joe
Contact the service center
Last post May 03, 2010, 02:21:19 AM
Last post January 20, 2011, 03:03:51 PM
Last post April 07, 2011, 06:35:26 PM
Last post July 14, 2011, 04:30:42 PM
Last post January 20, 2012, 06:49:21 PM
by iliveinakeg
Last post January 03, 2012, 09:13:13 AM
Last post March 07, 2012, 10:31:22 AM
by jazz4627
Last post May 05, 2014, 07:50:53 AM
by NJsquatch
