Author Topic: ALL SI Models - Larger History/Scrollback Cache  (Read 7575 times)
Offline n_texas_basser
  • Unit(s): 1198, 998, 788
  • Accessories: 2 GR-50's, Interlink, SI
« on: August 05, 2012, 09:19:22 AM »
Model:
ALL SI Models
Suggested Upgrade:
Explanation:
Ability to scroll back further than just what is visible on the Sonar, DI,SI; i.e. an increase in the cache.
Added in Software Version:
Comments on Update:
Re: ALL SI Models - Larger History/Scrollback Cache
« Reply #1 on: August 06, 2012, 10:35:22 AM »
This may take an enormous amount of memory to do.
If Humminbird does it, it will make the units more expensive,
as if they aren't already expensive enough.
« Reply #2 on: August 06, 2012, 08:30:53 PM »
I hate to say it, but Humminbird is already more $$ than Lowrance and they support it. This ability becomes even more valuable when scrolling to mark a GPS waypoint at the scrolled back positon, FORGOT to mention that! BTW, memory is CHEAP, it's a commodity...
« Reply #3 on: August 07, 2012, 07:48:49 AM »
I don't believe that Lowrance or any other Sonar manufacturer can do this.
It's true that you can record on both units to an SD card, then while viewing a recording, create new waypoints based on what's on the recording.  So, in essence, you are reviewing the history and making waypoints from it.  But ONLY if you have made a recording to an SD card.
To keep a real-time, ongoing cache of recent history is just
a plain waste of memory.  I think these units barely have enough
memory to do what they were designed to do.
I disagree, when you add up all the options, Lowrance is more expensive than Humminbird.
« Reply #4 on: August 07, 2012, 09:27:56 AM »
to clarify, Lowrance does not have an unlimited ability how to scroll back , what it does have is the ability to scroll back farther than the visible screen maybe 1.5 to 2 screens back from what is visible,this not only allows you to see the data  , but also the ability to set a waypoint from this view. This is similar to the function on Humminbird, however would just the ability to scroll back and set your waypoint further back than what is a immediately visible on the screen
Last post July 14, 2009, 01:08:15 PM
Last post October 10, 2009, 04:33:44 AM
by keizerh
Last post August 02, 2012, 07:31:38 AM
Last post November 02, 2010, 08:45:20 AM
by Moose1am
Last post February 18, 2011, 08:52:26 AM
by Daniele_Mari
Last post March 12, 2014, 12:37:19 PM
by N9Phil
Last post August 15, 2014, 08:49:34 AM
by Beaulieu80
Last post April 24, 2017, 04:03:53 AM
by allanrbaker
