Author Topic: ethernet on birds  (Read 6961 times)
Offline dkibat
  • Unit(s): 898SI
  • Accessories: Ethernet
ethernet on birds
« on: August 04, 2012, 04:56:56 PM »
what exactly does ethernet do? and does it transfer external gps puck module thru the console unit to the bow unit
Offline Roddy
  • Scan,scan and rescan
Re: ethernet on birds
« Reply #1 on: August 04, 2012, 08:18:10 PM »
dkibat, Ethernet shares GPS/NAV data between units, but NO SI,DI or DEAPTH!
If one unit has the GPS wired in the other can receive GPS and all other NAV.
Roddy
Scan,Scan and Rescan Roddy
Offline Rüdiger
« Reply #2 on: August 05, 2012, 02:05:57 PM »
Hi
Overt the ethernetport is it possible to get all information from the unit. The very good software DrDepth use this possibility.
mvh
Rüdiger
Finding is better than losing
« Reply #3 on: August 05, 2012, 02:30:01 PM »
It's also for communications between future accessories, such as the 360.
« Reply #4 on: August 06, 2012, 03:15:49 PM »
The Ethernet cable provides the same function as the Ethernet cable to your computer does (that is unless you are wireless): it is a means of transferring large amounts of data between units or unit(s) and accessory(ies).
Yes, you can transfer or share the GPS Receiver connected to a console unit with a bow mounted unit.  Other data may also be shared but this is more dependent on which units are connected.
Last post December 22, 2009, 09:12:00 PM
by soretoe
Last post January 25, 2010, 08:22:18 AM
by jejb
Last post August 03, 2010, 03:23:15 PM
Last post March 18, 2011, 03:21:13 PM
Last post June 27, 2011, 11:23:29 PM
by RzorbackAngler
Last post August 06, 2011, 03:14:28 AM
by SonarTRX
Last post November 02, 2013, 08:53:43 AM
Last post April 07, 2016, 01:17:58 PM
by rockfishbuster
