Author Topic: Brand new 798ci SI. Anything I NEED to know? :)  (Read 6696 times)
Offline massillonbuckeye
  • Unit(s): Onix 8nt SI, 788, AC Pro, LM Great Lakes
  • Accessories: Terrova/I-Pilot Link
« on: July 23, 2012, 11:16:07 PM »
Coming from a 597ci DI unit, this will be my first SI unit.  Installing it tomorrow.  Using primarily on inland lakes and reservoirs 60ft deep or less.  Looking to troll some of the contours of the lakes targeting the 10-25 ft range.  Will be sharing pictures of anything interesting I see, although some of these reservoirs and pretty bland I'm afraid!  We'll see though!
Offline Roddy
  • Scan,scan and rescan
Re: Brand new 798ci SI. Anything I NEED to know? :)
« Reply #1 on: July 25, 2012, 03:37:41 AM »
massillonbuckeye, Good installation is the big thing after that it is a learning thing. The more time on the water the better!
Good luck and enjoy!
Roddy
Scan,Scan and Rescan Roddy
« Reply #2 on: July 25, 2012, 09:55:41 AM »
I agree with Roddy.
Time on the water is going to be your best teacher.
Be patient and don't try and rush things.
It will take time to tweak things.
You may end up adjusting your transducer location.
Some suggestions:
With your boat in the water fully loaded, try and have the transducer
more or less flat against the water.
Set your max depth setting (on sonar menu) to 10 feet greater than the water you are
fishing.  Your sonar will be more responsive that way rather than on auto.
Try and match your SI chart speed to your boat mph speed.
When using SI keep in a straight line for best images.
If you have any interference issues, get a separate battery for your sonar.
Good Luck.
Last post December 05, 2009, 02:03:55 PM
by bassburner15
Last post May 18, 2010, 06:56:27 PM
by Takman74
Last post April 23, 2012, 06:51:14 PM
by Weekend Warrior
Last post December 28, 2012, 10:41:41 AM
by 234rick
Last post February 16, 2013, 11:06:43 PM
by Midtin
Last post June 18, 2013, 01:05:44 PM
Last post June 30, 2013, 12:30:02 AM
Last post September 27, 2017, 09:48:21 PM
by fishreed
