Author Topic: transducer  (Read 5544 times)
Offline 1966g3
  • Unit(s): 898c si
transducer
« on: July 22, 2012, 05:40:16 AM »
while im running on the water the place where my transducer is mounted throws a very high rooster tail should i lower it to stop this. the transducer works fine othrwise
Offline Roddy
  • Scan,scan and rescan
Re: transducer
« Reply #1 on: July 22, 2012, 07:17:53 AM »
Call HB and ask if there is a transducer plug made for your unit, might help.
Scan,Scan and Rescan Roddy
Offline George
  • Software: Always up todate
Re: transducer
« Reply #2 on: July 22, 2012, 05:49:20 PM »
1966g3
Do you have a picture of your installation?  It is possible that the transducer is too low in the water.  A plug may or may not help.
George
Re: transducer
« Reply #3 on: July 22, 2012, 06:39:16 PM »
Good suggestions so far.  What transducer do you have.
Lowering it will probably increase the roostertail.
As George said take and post pictures of your install...
Chuck.
Re: transducer
« Reply #4 on: July 23, 2012, 01:18:29 PM »
We don’t make a plug for the HDSi transducers – only for the smaller CSi transducers that are shipped with the 798 units.
Raising the transducer will help to get rid of the roostertail but it may also affect the ability of the transducer to get high-speed water depth readings.
Offline BCLII
  • Unit(s): 1198si, 998si, 788di
Re: transducer
« Reply #5 on: July 24, 2012, 10:05:10 AM »
Take electrical tape and wrap it around the open part of the bracket, this will eliminate the rooster tail!
Offline 1966g3
  • Unit(s): 898c si
Re: transducer
« Reply #6 on: July 24, 2012, 06:27:06 PM »
Thanks I will try this do you just wrap it around where it connects to the boat
Offline BCLII
Re: transducer
« Reply #7 on: July 24, 2012, 09:23:06 PM »
Yes, wrap it around the gap between the mounting bracket to the puck!
by Sonshine Fishing
Last post March 11, 2011, 12:39:09 PM
by bamafish
Last post March 24, 2011, 08:38:03 PM
by jjbch
Last post March 03, 2012, 08:38:18 AM
by FuzzyGrub
Last post August 09, 2011, 04:37:57 PM
by Brian37075
