Author Topic: using an extention cable with out a transducer connected.  (Read 4861 times)
« on: July 17, 2012, 06:41:22 PM »
Disconnecting the 2D transducer from an AS-Si-DB-Y cable may cause arching of the 2D transmitter and unit failure…
Just to side step for a minute...
Greg, a while back you had posted that running a transmitter on a long cable without the transducer was not going to hurt the unit.
Has this changed since the post?
Are we now to ensure that we dont have extention cables without a transducer??
Re: using an extention cable with out a transducer connected.
« Reply #1 on: July 18, 2012, 10:52:14 AM »
Difficult to answer question here Chuck as it depends on which model unit you are talking about… As a general rule I would not run a unit with only a transducer extension cable connected (no transducer connected to the extension cable).
« Reply #2 on: July 18, 2012, 04:14:15 PM »
OK, just trying to get a standard.
So we can run without a transducer connected but not if we have a cable in place.
Thanks, chuck
