Author Topic: 360 Imaging  (Read 12963 times)
Offline diver651
  • Unit(s): 1197, 1198
  • Software: 6.47
  • Accessories: Interlink, Aux Speed/Temp,
360 Imaging
« on: July 12, 2012, 12:55:19 PM »
Has anyone seen any information on what frequency the transducer in the new 360 imaging unit is operating at? I am trying to get a handle on what the resolution and maximum imaging distances will be in freshwater.
Offline Roddy
  • Scan,scan and rescan
Re: 360 Imaging
« Reply #1 on: July 12, 2012, 03:08:31 PM »
diver, Just spoke with HB CS! They know nothing about spec on the 360 units yet.
Roddy
Scan,Scan and Rescan Roddy
Re: 360 Imaging
« Reply #2 on: July 12, 2012, 03:21:18 PM »
Until the product has started shipping you will not see any specs on it.  This is pretty standard for us as some specifications could change at the last minute.
Offline W9GFO
  • Unit(s): 798ci HD SI
Re: 360 Imaging
« Reply #3 on: July 13, 2012, 11:03:53 PM »
It is supposed to work with the 798, which only supports 455 kHz.
Offline dalev
  • Unit(s): 998si combo
  • Software: 6.1
Re: 360 Imaging
« Reply #4 on: August 01, 2012, 10:10:33 PM »
Can anyone speculate whether normal side imaging views will be available along with 360 views in the view rotation?
Dale
Re: 360 Imaging
« Reply #5 on: August 02, 2012, 07:54:23 AM »
It is my understanding that the 360 will give a cheap sector scan to fishfinding..
the normal transducer for si will be used in concert.
Possibly some menu selection like 2d or si or downingaing..
But again we will need to see this in operation.
As Greg said before specs are help until release as production could change prior to release..
Offline dalev
  • Software: 6.1
Re: 360 Imaging
« Reply #6 on: August 02, 2012, 12:25:44 PM »
thanks
Re: 360 Imaging
« Reply #7 on: August 02, 2012, 12:56:13 PM »
Dale, if you get one of these let us know what all you find out..
Offline dalev
  • Software: 6.1
Re: 360 Imaging
« Reply #8 on: August 02, 2012, 06:16:43 PM »
WILL DO
DALE
Offline Roddy
Re: 360 Imaging
« Reply #9 on: August 03, 2012, 12:53:20 AM »
I have been bugging hummingbird about the 360 and keep getting  the same reply " I KNOW NOTHING! "
Roddy
Re: 360 Imaging
« Reply #10 on: August 03, 2012, 11:51:20 AM »
I would think that since the 360 is an accessory transducer,
the units will have the same views as always,
with the added 360 views.
I don't think it's intended to replace the normal
transducer.
Offline Roddy
Re: 360 Imaging
« Reply #11 on: August 03, 2012, 02:34:02 PM »
GEEK, As I understand it the SI xducer is required in order the system  to have a depth reading displaed.
360 transducer will require a SI transducer to have a depth readout.
Sounds like someone  forget  something about system efficiency  !
I can see the post now " I just spent  $ 2000.00 USon a new 360 and it does not display depths ".
Roddy
« Last Edit: August 03, 2012, 02:49:40 PM by Roddy »
Re: 360 Imaging
« Reply #12 on: August 03, 2012, 03:18:50 PM »
Well,
Like I said, it is an added accessory.
It will work off the main system, the main system won't work off of it.
I'm not surprised that it requires a piece of the main system to get the
depth.
You're right Roddy.
People will buy it and think that it's a complete system and complain
about it.
I saw a review on Amazon where someone bought the XM AS1 Weather
module, then was pissed off that they had to get a monthly service
plan from Sirius.  Best to research before you buy.
Offline Jim Jack
  • Unit(s): 998
Re: 360 Imaging
« Reply #13 on: August 03, 2012, 04:25:33 PM »
Info I have says you just need 200k source to get depth, so you do not really need normal SI TD.
I read that XM review on amazon just today when I ordered my XM weather receiver (199.99), I just laughed.
Offline Roddy
Re: 360 Imaging
« Reply #14 on: August 04, 2012, 01:17:23 PM »
Talk about a laugh, the mounts run $56.00-$250.00USD :o now thats a CRY!! :'( :'(
The inatallation could run as high $500.00USD! :o :'( :-X
Hope I never forget to retract the transducer and GUN it WTFO to 90MPH !!$$$$$$$$$
Roddy
« Last Edit: August 04, 2012, 01:27:44 PM by Roddy »
Re: 360 Imaging
« Reply #15 on: August 06, 2012, 02:48:04 PM »
ITG is correct: the 360 Imaging is an accessory.  The same Views that are available now will be available if you get one of these plus the added Views from the 360 Imaging will be available.  Just like adding radar or connecting boat motor gauges through the NMEA2K accessory.
Offline dalev
  • Software: 6.1
Re: 360 Imaging
« Reply #16 on: August 08, 2012, 09:33:16 PM »
Thanks Greg.
I'm a bit confused about views. Who creates them? Can a user create a combo view? if so, do u think u can create a combo view  with the 360 and say downscan or sonar?
DALE
Re: 360 Imaging
« Reply #17 on: August 09, 2012, 06:57:16 AM »
HB decides what views the user needs or wants.  They put them into a menu that you will select from..
Re: 360 Imaging
« Reply #18 on: August 09, 2012, 10:56:26 AM »
The Views are predefined (the user cannot create them).
I do not know what Views will be available for the 360 Imaging accessory.
Last post August 31, 2013, 11:47:23 PM
Last post September 09, 2013, 11:02:38 AM
by Doc Stressor
Last post January 12, 2015, 07:14:09 AM
by vik33
Last post January 27, 2015, 04:44:51 PM
by Doug Johnston
Last post February 13, 2015, 11:44:06 AM
by hgv
