Author Topic: Seeing your jig under boat  (Read 8409 times)
Offline iowafuzz
  • Unit(s): 898c si
« on: July 10, 2012, 12:01:49 PM »
Just got back from Wis. crappie fishing and tried to see if I could get my jig on the screen like I've seen other do.  Could not do.  :(  Don't ask me what setting I used, as I tried a bunch of different settings (switchfire on - off) to no avail.  Fished/trolled/drifted in water anywhere from 6 ft. to 30 ft.
What is the minimum depth this can be done?
Most important: What are the settings you use to make this happen?  Cone setting and etc.?
Does jig have to be exactly under the transducer?
Any info and help would be greatly appreciated as I like to drift over schools and sometimes spot lock over schools with Terrova.
Thanks in advance,  Fuzz   :)
Re: Seeing your jig under boat
« Reply #1 on: July 10, 2012, 07:20:51 PM »
You will get the best results with switchfire max and boost the sensitivity just a little.
The jig does need to be in the transducer beam.  I think the beam width at 83 khz is approximately 1/3 the depth....so, if you are jigging 10' deep, you would have to be within 3' of the transducer.....and even then you would be on the edge of the beam.....the closer you are jigging to your transducer the better.
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #2 on: July 11, 2012, 12:04:20 AM »
closer to your transducer the better, calm to light winds, the deeper the water the better.. .and yes, make sure it's in the sonar cone. start bumping sensitivity until you see it. You could always start with an anchor :)
Offline ZX225SK
  • Unit(s): 898-997
« Reply #3 on: July 23, 2012, 09:11:10 AM »
I have done this may times bass fishing I have noticed you just about always be in light wind sonditions so boat does not move very much. If you are drifting very much I have found it hard to keep your bait with transducer profile. I have been able to see my bait at depths up to 40 feet. even a crappie jig can be seen at this depths.
Last post February 28, 2014, 07:51:15 AM
by mako101
Last post March 12, 2014, 01:47:26 PM
by Tjo
Last post April 06, 2015, 11:07:33 AM
Last post March 28, 2016, 02:01:11 PM
by bobcoy
Last post September 24, 2017, 10:00:42 PM
Last post November 30, 2017, 12:15:07 PM
by Diesel Pro
Last post February 25, 2020, 04:02:58 AM
by Rüdiger
