Other Interest
DIY - Side Scan Sonar and towfish
Topic:
Variable ballast
« previous
next »
Print
Pages: [
Go Down
Author
Topic: Variable ballast (Read 5994 times)
Rüdiger
Sr. Member
Variable ballast
on:
June 30, 2012, 03:25:30 PM »
Depending on the depth in wich the Towfish should run, the weight can be changed.
I`m using 6 stainless steel weights a.500g that can be moved as needed on the threaded rod.
mvh
Rüdiger
Logged
Finding is better than losing
sonar2000
Chief
Global Moderator
It is not lost ...it has been misplaced.
Unit(s):
(1) 1197 (1) 1198
Software:
6.6
Accessories:
Tow Fish
Re: Variable ballast
Reply #1 on:
June 30, 2012, 05:03:16 PM »
that is a great idea and certainly takes a lot of work out of adjusting for depth.
Very simple and easy to adjust..
Good job.
Logged
Print
Pages: [
Go Up
« previous
next »
Smf
Other Interest
Topic:
Variable ballast
Subject / Started by
Replies
Last post
variable gain for side imaging
Started by
tournevase
Helix Series Units
December 18, 2025, 04:26:15 AM
by
tournevase
