Author Topic: Fish over board  (Read 10825 times)
Offline Rüdiger
Fish over board
« on: June 30, 2012, 03:18:54 PM »
Since I am alone in the boat, I needed a solution that allows Towfish to have handed to water.
A bipod with cable pulley at the stern of the boat keeps the remains of fish in each case, behind the engine and thus out of reach of the voracious propeller. Thus, the end of each scan line Towfish raised and lowered again after the turn.
Towfisher and how you do it? :-\
mvh
Rüdiger
« Last Edit: June 30, 2012, 03:22:37 PM by Rüdiger »
Finding is better than losing
Offline kron
  • Unit(s): 997c SI
Re: Fish over board
« Reply #1 on: June 30, 2012, 04:09:26 PM »
Looks good. Exactly what i want as well. My concerns is that the cable will get broken when being pulled over the pulley. Do you also have an ethernet cable to the fish?
Daniel
Offline Rickard
Re: Fish over board
« Reply #2 on: July 01, 2012, 02:13:37 AM »
That looks as a very clever system. I suppose you can lift the fish up to the pulley and then swing the 'crane' backwards to get the fish over the outboard engine and into the boat? My 'system' is not that advanced, in my smaller boat I use a fixed wood plank with a pulley. The plank sticks out horizontally behind the motor and I need a stick to press the cables with the towfish from the pulley. A bit clumsy, but it works.
On my large boat I simply deploy the towfish from the side of the boat. When towing the cable is routed one turn around a pulpit post at the starboard side and secured to the deck with a clam cleat. I use a PVC coated steel wire for towing and the ethernet cable is just attached to the wire.
Rickard
Offline Rüdiger
Re: Fish over board
« Reply #3 on: July 01, 2012, 03:04:41 AM »
Hi Daniel
No, I am currently using three extension cable of HB and I have chosen for the role of an extra-large diameter in order to increase the contact surface for the cable.
mvh
Rüdiger
Offline kron
  • Unit(s): 997c SI
Re: Fish over board
« Reply #4 on: July 01, 2012, 03:48:54 PM »
Okay.
Is the tube around the cable like an hollow waterski rope?
Daniel
Offline Rüdiger
Re: Fish over board
« Reply #5 on: July 02, 2012, 03:34:19 AM »
Okay.
Yes, but only the first 6m, 30m further reinforced with a rope.
mvh
Rüdiger
Last post April 02, 2009, 06:52:38 AM
Last post January 14, 2011, 04:20:45 PM
Last post November 12, 2010, 09:49:20 AM
by Phiznat5000
Last post March 22, 2011, 10:18:28 AM
Last post March 24, 2011, 11:24:26 PM
Last post July 31, 2015, 11:44:21 AM
Last post June 22, 2016, 10:54:10 AM
by RV Sam
Last post January 19, 2017, 08:13:56 AM
