Author Topic: help explain Sonic View  (Read 8124 times)
Offline firetiger
« on: June 17, 2012, 11:24:21 PM »
page 40 user manual
Using the 4-way cursor control key move the to a sonar return. I understand all the readouts at the top of
screen except for #9 bearing. Bearing is relative to what? I want a view that shows the position at 3:30. A bearing value in itself doesn't mean anything to me. Any comments would be appreciated!
Offline W9GFO
  • Unit(s): 798ci HD SI
Re: help explain Sonic View
« Reply #1 on: June 18, 2012, 02:02:14 AM »
I believe it is the direction you are traveling relative to true North. As opposed to heading which is the direction the boat is pointing - often not the same as the direction it is moving.
http://en.wikipedia.org/wiki/Bearing_(navigation)
Offline firetiger
« Reply #2 on: June 18, 2012, 08:04:03 AM »
Sounds reasonable to me, the 'relative to true north' part. However I don't think the bearing is a direction the boat is traveling. The view is a sonic view, providing the bearing on which the boat is travelling would be of little value. I think the bearing is the direction to the cursor postion. The question: what view shows the bearing on which the boat is travelling so I can turn the boat toward the cursor position?
« Reply #3 on: June 18, 2012, 08:18:14 AM »
I think if the boat is moving along, and it shows a bearing, it is the bearing in relation to
North.
But, I think if you put the cursor on a sonar object, then the bearing shown is
in relation to your boat position.
« Reply #4 on: June 18, 2012, 01:35:44 PM »
ITG is correct.  So 0/360 degrees would be in the same direction the that boat is moving.  90 degrees would be at a 90 degree angle to the right of the direction the boat is moving while 270 degrees would be a 90 degree turn to the left.  If you GOTO function at the cursor position than you can use any of the Chart Views should be able to show a direction you would need to go to get there.
Offline firetiger
« Reply #5 on: June 18, 2012, 04:21:16 PM »
Thanks for the comments! Will be out on Silver Lake WA starting Thursday and will put your comments to the test
Last post June 08, 2012, 10:05:31 PM
by psloan43
Last post January 25, 2010, 08:22:18 AM
by jejb
Last post March 01, 2010, 04:10:05 PM
Last post September 29, 2010, 08:41:36 AM
by Enufzed
Last post January 31, 2011, 01:31:22 PM
Last post October 19, 2011, 03:38:38 PM
by Solowolf
Last post April 14, 2011, 09:31:38 PM
by inshorecatch
Last post August 12, 2014, 01:30:19 PM
