Author Topic: Humminbird 898c si losing power when hitting a wave  (Read 14332 times)
Offline sarasotawingman
  • Unit(s): 898c si
« on: June 07, 2012, 02:52:49 PM »
I am having an issue where when I hit a large wave that gives the boat a good jolt - the unit powers off. I have to then power it back up.
The guys checked the power cable and said the voltage is good. I am wondering does anyone else have this problem? I extended my warranty out another year so I have more time to deal with this - I just hate to have to have to pull it out of the dash and send it in. I'm wondering if it is a loose connection. Any suggestions?
Re: Humminbird 898c si losing power when hitting a wave
« Reply #1 on: June 07, 2012, 03:14:16 PM »
It is most likely an intermittant loose connection,
if the unit works well most of the time.
You can try bending your power cord connections out a little
for better contact (don't bend both at the same time or you will blow a fuse).
Check your connections and fuse at the battery also.
  • Unit(s): 898c si
« Reply #2 on: June 07, 2012, 03:18:24 PM »
I think I am going to try the bend trick this weekend. I have been reading about that on a few other forums.
I didn't install the unit. What tools do I need?
« Reply #3 on: June 07, 2012, 05:20:55 PM »
Needle nose pliers....
I would recommend removing the fuse first so you don't accidenty touch the positive and negative pins at the same time with the pliers ... This would blow the fuse as Itgeek said...
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #4 on: June 07, 2012, 07:10:42 PM »
depending on how the sonar is wired, just start moving power wires to see where the bad connection is. Could be a loose battery connection, loose fuse panel/box connection, or bad ground somewhere. Is it only the FF doing this or are there other devices powering off? Are the connections on the back of the unit nice and tight? That's about all I can suggest to try with the boat off the water.
Offline staoB regnaR
  • Unit(s): 998,788
  • Software: 6.18, 6.25
  • Accessories: GPS reciever
« Reply #5 on: June 07, 2012, 07:48:29 PM »
I have the same problem with my 998. It only does this sometimes though. I've looked around and haven't found anything loose
Ranger Boats, Strike King, Berkley, St. Croix, Quantum, Omega, Wired2Fish.
« Reply #6 on: June 07, 2012, 07:56:35 PM »
A lot of places to look but I would bet it is the pins in the HB connector..
  • Unit(s): 898c si
« Reply #7 on: November 20, 2012, 03:14:56 PM »
FYI I was able to bend the pins with a piece of plastic I had on the boat. Just something to slightly move them away from each other. Been out many times since and the nav has not once cut off so that was the fix. Much appreciated everyone. I guess now it just makes a better connection.
Last post September 09, 2009, 08:59:50 PM
Last post June 07, 2010, 10:59:47 PM
by Takman74
Last post August 02, 2011, 02:04:27 PM
by edwardpic
Last post June 15, 2012, 06:37:54 PM
by jsiegle24
Last post October 21, 2013, 10:38:26 AM
Last post March 10, 2014, 12:56:10 PM
Last post March 06, 2017, 07:18:36 PM
by hutcher1
Last post December 30, 2020, 03:54:44 AM
by Rüdiger
