Author Topic: GPS Question when to drop the MArker??  (Read 10145 times)
Offline tomb.rx
  • Unit(s): 798 ci 587 ci
« on: June 01, 2012, 05:19:23 PM »
hey guys quick question when i mark something like a rock pile and then double back to it when should i drop a marker bouye in the water when the tip of the boat on the gps touches the marked point ?? or when the whole boat is covering the marked point?? or when i start seeing returns of the rock pile on the unit when you do split screen gps and 2D sonar?? my unit is installed in the counsle and it is an internal antena.  thanks in advance
PS i also have a side imaging installed on the trolling motor anyone know of a trick you can do to keep the trolling motor straight when you take your foot of it. it always ends up spinning around to one side or the other sometimes it behaves and stayes straight even if my foot is off from it but rarely thanks again
Offline Trytoofish
  • Software: 2.0, 7.51,
Re: GPS Question when to drop the MArker??
« Reply #1 on: June 01, 2012, 05:43:03 PM »
when you see it on the screen.
Try Too Fish  Forced To Work
Offline Roddy
  • Scan,scan and rescan
« Reply #2 on: June 01, 2012, 10:29:40 PM »
Trytoofish, Yep as soon as you see it Drop it behind the boat!
Roddy   >:D
« Last Edit: June 01, 2012, 10:30:47 PM by Roddy »
Scan,Scan and Rescan Roddy
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #3 on: June 02, 2012, 01:07:41 AM »
tomb.rx
     Being as I don't type worth a xxxx, here is a link to an excellent three part article explaining what your up against.
     Unfortunately it's not as simple as you would think. Read all three parts. Adam is a former HB employee and gives
     the best explanation I've seen of this concept.
    http://www.biggeorgiaspots.com/boats-and-electronics/gps-and-cartography.html
    If you have the time, read all the articles under " Boats & Electronics ". They really helped me be a better sonar operator.
                           Mike
Last post December 28, 2009, 03:03:38 PM
by soretoe
Last post January 15, 2010, 04:48:50 AM
Last post January 30, 2010, 05:46:53 PM
Last post May 11, 2010, 01:01:17 PM
by cdgreentn
Last post August 23, 2010, 02:40:53 PM
by DoubleGobble00
Last post October 14, 2014, 07:41:13 PM
by slabbacks
Last post July 09, 2023, 06:14:42 PM
Last post October 14, 2023, 10:38:46 AM
by Blacklab
