Author Topic: TD alignment for DI and SI  (Read 4324 times)
Offline rdstair
  • Unit(s): 1198C SI, 998C SI
« on: May 27, 2012, 02:15:56 PM »
I think I already know the answer  to this question. For proper readings does the TD have to be level horizontaly with the water or can it be at the same angle as the bottom of a deep vee boat. I think you would not get the proper reading because the DI would be looking slightly to the side instead of straight down.
Re: TD alignment for DI and SI
« Reply #1 on: May 27, 2012, 03:20:24 PM »
For best performance (2-D, SI, DI):
With the boat fully loaded, at normal operating weight, and on the water.
Side to side:Exactly level.
Front to back:It can be tilted with the front a little lower than the back.
Bear in mind too, that the attitude of the transducer will be different while at
rest and while underway.
When the bow raises (with speed), the front of the transducer tilts upward because the
stern squats deeper in the water.
This will show more of what's under the mid and front of the boat (while underway), rather than what's directly under the transom, at rest (for transom mounted transducers).
Last post September 28, 2014, 05:51:31 PM
by mike fish
