Author Topic: Installed Humminbird on Stratos 201XL Evolution  (Read 5287 times)
Offline George
  • Software: Always up todate
« on: May 19, 2012, 06:38:19 PM »
This how I installed my unit.
Drilling thru Gel-Coat
Many of you may know this but I did not.
You must get through the gel-coat before drilling fiberglass.  The gel-coat is very brittle and will crack, break or flake.
To drill a hole for bolts, I start with small bits and work up to the size I need.  Start with drilling the hole backwards, it will wear through the gel-coat, if you start drilling there is a pretty good chance you will start flaking the gel-coat.  Do this all the way up to the size hole size needed.  Then chamfer the hole by running a larger bit backwards until the the chamfer is through the gel-coat.
Note if the screw or bolt is to big for the hole, there is a good chance that again it will flake a piece of gel-coat, I did this on my first screw hole to mount a transducer.  After that I was more careful.
George
« Last Edit: May 20, 2012, 07:31:34 AM by George »
Last post May 23, 2009, 01:08:50 AM
by keizerh
Last post April 21, 2010, 11:19:45 PM
RaptorCap installed
Started by Wayne P. 798c SI
Last post June 18, 2010, 10:49:10 PM
Last post July 29, 2011, 09:52:30 AM
Last post January 08, 2012, 05:37:08 PM
Last post May 08, 2012, 02:58:00 PM
Last post July 03, 2012, 01:57:17 PM
Last post April 28, 2016, 09:47:15 PM
