Author Topic: Which screen protector do you use?  (Read 21682 times)
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« on: May 02, 2012, 10:30:36 PM »
And if you had to replace it, would you buy the same or a different brand?
Re: Which screen protector do you use?
« Reply #1 on: May 02, 2012, 11:14:49 PM »
http://www.screenpatronus.com/
Yes.. I would use the screenpatronus again...
I found it easier to work with than the Zagg... Not as sticky...and half the price...
Offline xSilmarilSx
  • Software: 6.250 - 5.320
« Reply #2 on: May 03, 2012, 03:12:21 AM »
I've got a Zagg on my 778 and 798.
I choose that brand from user on a HB forum.
A little pricey, but the product does it's job.
And super easy to install, like all screen protectors if you use
the good technique.
« Reply #3 on: May 03, 2012, 07:23:04 AM »
For my 1197, I've got the Lexnard true vue anti-glare protector.
It's a little tricky to install without getting air bubbles under it.
It's very good, I would buy it again.
Offline xSilmarilSx
« Reply #4 on: May 03, 2012, 01:14:24 PM »
The best way to not have air bubbles, and it's easy since our units are waterproof, is to put the unit horizontally and make a pool of water on the screen before putting the protector.
And make sure you have pre-cleaned the unit screen thoroughly and dried with a lint-free cloth or paper.
Myself, I use wipes made for cleaning lenses.
It's only a 10 minutes job and works like a charm every time!
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #5 on: May 03, 2012, 11:18:56 PM »
Thanks to all that responded. Doesn't appear to be a dominate player.
ITGEEK-- Being that one of the main complaints about our units is the readability
              in direct sunlight; do you think the Lexnard anti-glare makes this better?
« Reply #6 on: May 04, 2012, 07:37:46 AM »
newkid4si:
I definitely think it makes it better.
I also have a Team Waters plastic sun shield.
This hangs over the top and sides of the unit, to help
block the sun.
These accessories compliment each other nicely.
« Last Edit: May 04, 2012, 07:44:28 AM by ITGEEK »
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #7 on: May 05, 2012, 12:45:24 AM »
ITGEEK
         NK
Last post June 02, 2012, 05:56:44 PM
by Troutcatcher
Last post June 04, 2012, 12:32:57 AM
by Troutcatcher
Last post April 07, 2010, 09:55:07 PM
Last post April 25, 2010, 11:19:54 PM
by scoeri
Last post August 31, 2010, 01:39:59 PM
by Daniele_Mari
Last post January 14, 2013, 04:30:23 PM
Last post March 28, 2014, 03:48:45 PM
