Author Topic: mark button ISSUES !!!  (Read 12321 times)
Offline blaze 226
  • Unit(s): 798 ci hd
  • Software: 6.250
« on: April 24, 2012, 08:32:16 PM »
sometimes when i hit the mark button on my 798ci it will flash and reload over & over until i cut the power off . has anyone else had this issue ?
« Last Edit: April 24, 2012, 08:37:11 PM by blaze 226 »
Re: mark button ISSUES !!!
« Reply #1 on: April 25, 2012, 08:58:56 AM »
Yes, check the search tab at the top and look at what has been previously posted..
Not sure of fixes and such but somethings relate to code upgrades or downlevel issues.
This has occured over several models..
« Last Edit: April 25, 2012, 09:00:07 AM by sonar2000 »
« Reply #2 on: April 25, 2012, 12:07:55 PM »
blaze 226,
Try saving all of your waypoints, tracks and routes (aka: Nav Data) to an SD memory card and than to your computer via HumminbirdPC.  Than delete all of the Nav Data from your 798ci unit and see if it still happens.
Offline blaze 226
  • Software: 6.250
« Reply #3 on: April 25, 2012, 07:10:48 PM »
I just bought my unit April, 12 2012 . It started cutting off the next day. I contacted humminbird & they said to get a new unit . He said the keypad was probley bad since it was so new . I wanted to make sure it wasn't a wiring issue or something simple to fix. Thanks for the input & the great info on this forum.
« Reply #4 on: April 25, 2012, 07:33:54 PM »
HB support is probably right especially if new.  there were some keyboard (button) issues.
Can you return for a fix?
chuck
« Reply #5 on: April 26, 2012, 10:38:03 AM »
Gotcha Blaze – I did not know that it did this from the beginning.  Sounds like it could be a keypad or internal keyboard issue that will need to be fixed.
« Reply #6 on: April 26, 2012, 11:04:50 AM »
If HB wants it back then send it.  they know the issues with the button.
Also if you search on the forum you will find posts to suport flacky keypads..
Mostly they are good but there was some problems a while back..
Call support and get return authorization.  They should pay for the shipping..
Offline blaze 226
  • Software: 6.250
« Reply #7 on: April 27, 2012, 08:00:15 PM »
I got my new unit in today went to check it out. So far working fine . Thanks for all the help Greg & Chuck .
« Reply #8 on: April 28, 2012, 05:16:59 PM »
blaze,  get out and use that fishfinder.
And be sure to show us some pictures of the big fish you catch.. ;D
Last post April 08, 2009, 02:27:21 PM
Last post September 11, 2014, 03:34:49 AM
Last post November 10, 2010, 08:39:08 PM
by maachuu
by fishinphil
Last post November 08, 2011, 09:57:24 AM
Last post July 02, 2012, 12:17:46 PM
by greatlakes
Last post January 29, 2013, 10:41:01 AM
Last post August 12, 2015, 10:35:00 PM
by ricqik
