Author Topic: universal sonar  (Read 10442 times)
Offline Patty
  • Unit(s): 898c SI
  • Software: 6.4??
universal sonar
« on: April 16, 2012, 09:27:31 PM »
I was just wondering what frequency minn kota's universal sonar transducer uses? i have a 550x hummingbird on the bow and was wondering what settings i should be using... couldn't find any info on minn kota's site....
thanks
James Patterson
Re: universal sonar
« Reply #1 on: April 17, 2012, 08:58:37 AM »
Not sure of the freq but on your HB look for interference if both are on.
If there is none then it should be away from the HB freq..
I will look around for the mink freq..
Since they advertise the type for HB dualbeam it very well may be within the HB spectrum.
Chuck..
« Last Edit: April 17, 2012, 10:28:56 AM by sonar2000 »
Offline Patty
  • Unit(s): 898c SI
  • Software: 6.4??
Re: universal sonar
« Reply #2 on: April 17, 2012, 10:20:54 AM »
thanks... i've never noticed interference with it yet... i'm thinking of upgrading it anyway was just curious more than anything....
Re: universal sonar
« Reply #3 on: April 17, 2012, 10:29:42 AM »
Keep us updated.
Thanks and good luck
Re: universal sonar
« Reply #4 on: April 17, 2012, 11:02:58 AM »
I found this on the web:
Minn Kota has designed and utilizes a 196 kHz transducer that operates within a + or - range of ~ 6 kHz (190 kHz - 202 kHz) effectively covering the frequency range without sacrificing performance.
Offline Patty
  • Unit(s): 898c SI
  • Software: 6.4??
Re: universal sonar
« Reply #5 on: April 17, 2012, 12:13:47 PM »
Okay... so that would prob work best with a 200khz setting on any unit then? would it cover 83/200?
Re: universal sonar
« Reply #6 on: April 17, 2012, 12:40:17 PM »
The older Universal Sonar had only the 200kHz sonar capability while the newer US2 sonar has the 200/83kHz sonar capabilities.  So any Humminbird 200kHz only unit would work on either one.  The 200/83kHz capable Humminbird units would need to be paired with the newer US2 or only the 200kHz part of their sonar will work correctly.
Last post April 24, 2012, 12:01:35 AM
by Gattlin
Last post January 04, 2012, 12:35:03 PM
Last post November 14, 2012, 08:37:46 PM
by flatcat_auz
Last post June 25, 2012, 04:40:42 PM
by flatlandfisherman
Last post July 03, 2012, 09:35:33 AM
by CatChaser
Last post September 26, 2013, 04:26:05 PM
Last post January 28, 2016, 02:11:24 PM
by tambrose76
Last post April 19, 2015, 06:29:19 PM
by offthehook67
