Author Topic: NO SI choice??  (Read 5692 times)
Offline RickT
  • Accessories: 798ci SI Combo
NO SI choice??
« on: April 11, 2012, 11:24:06 PM »
Ok so I bought a new 798ci and it was working fine, now I don't have under sonar the SI choice, WHat am i missing, thanks...
Offline Shooter00
  • Unit(s): 798c SI 788ci HD
Re: NO SI choice??
« Reply #1 on: April 12, 2012, 09:32:09 AM »
Click on views and bring up your SI screen and then click menu once or twice to bring up the menus.
Offline RickT
Re: NO SI choice??
« Reply #2 on: April 12, 2012, 10:12:02 AM »
I did what you wrote but I still don't get the choice of 455 Mhz, on the SONAR menu, Now just so you know the boat it out of the water..
I get the choices of 83/200 Mhz...
I even reseted the unit to dafault, but nothing..
Any other ideas????
Offline wolfs4evr
Re: NO SI choice??
« Reply #3 on: April 12, 2012, 10:50:19 AM »
Not sure what you are looking for.  As far as Sonar 83 or 200 or 83/200 will be your only choices.
The 798 is only capable of 455 as far as SI/DI and there wouldn't be any other options.  You would have to upgrade to a 800, 900 or 1100 series to get choices as far as SI/DI and then it would be 455 or 800.
Offline wolfs4evr
Re: NO SI choice??
« Reply #4 on: April 12, 2012, 10:57:11 AM »
This is what you should be seeing.  The option to change SI/DI isn't there since the 798 isn't cabable of anything else other than 455.
Offline wolfs4evr
Re: NO SI choice??
« Reply #5 on: April 12, 2012, 10:58:03 AM »
If you are looking for something like this then you would need to upgrade to a 800 or higher unit to get different frequencies for SI/DI.
Last post August 08, 2012, 11:24:38 AM
