Author Topic: does the 898 c si tranducser read temp?? if not what do i need?  (Read 14233 times)
Offline Southbound
  • Unit(s): 898C SI
  • Accessories: non
  Read above
Re: does the 898 c si tranducser read temp?? if not what do i need?
« Reply #1 on: April 07, 2012, 04:41:55 PM »
Yes it should unless you have ordered a different transducer..
You might have to set your readout to get the temp.
You should have the XHS 9 HDSI 180 T transducer..
chuck
« Last Edit: April 07, 2012, 04:46:17 PM by sonar2000 »
Offline Southbound
  • Unit(s): 898C SI
  • Accessories: non
« Reply #2 on: April 09, 2012, 08:26:48 AM »
I looked in the owners manual and could not find how to adjust the readings on the side bar.  you have any quick tips?
« Reply #3 on: April 09, 2012, 08:36:28 AM »
Under your setup menu, you should have
select readouts and select nav readouts.
This is where you select the readouts for the different views.
Offline Southbound
  • Unit(s): 898C SI
  • Accessories: non
« Reply #4 on: April 09, 2012, 11:15:13 AM »
 Got it thanks for the help.
« Reply #5 on: April 09, 2012, 11:28:47 AM »
South....Also make sure you have turned on the xpress menu...
« Reply #6 on: April 09, 2012, 11:51:28 AM »
Chuck,
I am confused at your post above.  You cannot turn on and off the X-Press menus (they are always on).  Are you meaning something else instead?
« Reply #7 on: April 09, 2012, 11:58:00 AM »
Is that advanced on to get express.  I may have to go back to the book..
« Reply #8 on: April 09, 2012, 01:41:24 PM »
I think that you are thinking about the Advanced menus Chuck.
There are three different levels of menus:
1.  X-Press menus only show up on the View (Sonar View, Chart View, Si View,…)
2.  The Normal (User Mode) menus show up in the tabbed main menu system all of the time.
3.  The additional Advanced (User Mode) menus only show up in the main tabbed menu system when the User Mode menu is set to the Advanced menu setting.
« Reply #9 on: April 09, 2012, 02:34:30 PM »
Probably so greg.....
The menus can be a bit tricky unless you use them all of the time..
Hidding a view can also make you think something else is not there.
If we forget we hid it.
A lot of choices in the menus, which on one hand gives the user some choices, but on the other you really have to known your screens.
And add to that differences in units..Especially software levels..
« Reply #10 on: April 09, 2012, 05:10:34 PM »
Chuck, it is a bit easier when you only deal with one brand instead of multiple brands of electronics.
« Reply #11 on: April 09, 2012, 05:26:58 PM »
Greg, I was only referring to the HB series of products. I dont even want to think about mixed vendors yet..
If I only had one unit it might be easier but we have three and all dfferent HB units..
Each has a unique way of handling certain things..
I spend more time trying to figure out how to than I do fishing.. ;D
chuck
Offline blackberg
  • Unit(s): 898csi
« Reply #12 on: May 19, 2012, 04:55:52 AM »
Mine never worked with the transducer, I tried with 2 new ones,  bought a temp sensor and it works
-bb
Last post March 31, 2013, 09:44:32 PM
by Rough House
Last post September 21, 2009, 09:10:00 PM
by werndog
Last post May 12, 2010, 05:26:05 PM
by Flynnme
Last post February 24, 2012, 02:27:44 PM
Last post May 01, 2012, 12:52:17 PM
by xSilmarilSx
read out
Started by T.G 898c SI
Last post May 07, 2012, 02:17:55 AM
by T.G
Last post June 22, 2012, 08:08:40 AM
Last post July 26, 2013, 11:25:20 AM
