Author Topic: Change in scanning color???  (Read 10027 times)
Offline basszilla
  • Unit(s): 898c SI & 587ci & 998c HD SI
  • Software: Current
« on: April 01, 2012, 10:00:59 PM »
Question:  Why does my unit change to a darker color by itself without moving settings.  In the pics I am at 24 feet were the road bed is.  Then the break drops to about 28 feet, but the color of the scanning becomes darker.  The darker scanning continues.  I under stand that the unit does the darker shading to tell the user that there is a change in depth.  I have pictures of scans were I am 30 plus feet with breaks and the unit will not have the change of color.  This has also happen during shallow scanning.  Any suggestions???  Thanks in advance...
Offline calli1
  • Unit(s): 1198 S I & 787c2i
Re: Change in scanning color???
« Reply #1 on: April 01, 2012, 10:55:47 PM »
From what I am seeing is the change in contour of the bottom of the lake.  If the bottom colors get brighter all of a sudden then that means a possible harder bottom as well as a humpr or shallower waters.  When the colors fade to lighter...then I would say a gradual decline in the bottom where the water is getting deeper.  When this happen the beam can't scan the bottom as well but on a sudden rise in the scan zone...the bottom will appear a much brighter color.
Offline lcookie
  • Unit(s): 998SI/1198SI/788DI/587DI
  • Software: 6.68/6.64/6.64/6.09
  • Accessories: Ethernet, GRHA, ASGPSHS,WeatherSense
« Reply #2 on: April 02, 2012, 01:44:26 PM »
Most likely it is due to a change in bottom hardness since your depth did not change that much.  Soft bottom equals darker returns.
« Reply #3 on: April 03, 2012, 05:21:08 PM »
When the color of the Si sonar returns turn darker; it is an indication that whatever the bottom of the lake/river is made of, it reflects less sonar energy back to the transducer.  This normally means a software material (say from rock to mud) but it could also mean that the surface of the bottom is angled away from the transducer.
« Reply #4 on: April 03, 2012, 05:24:53 PM »
HB has a good write up on sonar returns in the book or disk. It is also available in the web site.
It explains the returns real well..
Last post February 22, 2010, 06:01:01 PM
Last post March 20, 2010, 07:38:48 AM
Last post March 21, 2010, 03:27:27 PM
Last post May 29, 2010, 02:55:20 PM
Last post August 12, 2013, 07:46:10 AM
by Chapaj
Last post September 02, 2011, 12:34:45 PM
Last post January 23, 2014, 08:32:11 PM
by riverlogger
Last post July 04, 2020, 09:56:24 PM
