Author Topic: Headsup courseup northup setting  (Read 7804 times)
« on: March 29, 2012, 08:52:59 AM »
LittleGazoo posted this in another topic and I tried to split it out which did not work as intended.
So here is his post in a new topic..chuck
I noticed today when trying to set my Chart Orientation(Northup, Headup, Courseup), I had to select Headup to get Courseup.  And no one doesn't know what Headup means still.
Humminbird got a bug.
Re: Headsup courseup northup setting
« Reply #1 on: March 29, 2012, 10:28:50 AM »
LittleGazoo, could you explain this a little more please?
« Reply #2 on: March 29, 2012, 12:30:40 PM »
I've never heard of Headup.
Courseup changes the screen too much for my liking.
I personally prefer Northup.
« Reply #3 on: March 29, 2012, 01:21:22 PM »
I believe that headup is really a courseup ......
« Reply #4 on: March 29, 2012, 06:48:56 PM »
I did some checking around and cannot find a heads up setting in any unit.
I would guess the may be a local name for course up..
LittleGazoo  can you give us the unit type you have this setting selection on?
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
« Reply #5 on: April 09, 2012, 04:52:43 PM »
Humminbird 6.180 is a feature release.  One feature enhancement is to the Main Navigation Tab item Chart Orientation where your options are north-up, head-up or course-up.
North-up   displays your map with a north direction orientation.
Course-up displays your map with a course direction orientation.
Head-up    displays your map with a heading direction orientation.
If you have a waypoint, set a heading to it, then Head-Up will orient map so the waypoint heading is to top.
Very similar to course-up, but a little different.
« Reply #6 on: April 09, 2012, 05:17:42 PM »
Wow, thanks for the information.
These units are going quite technical..
I guess next we will have a go home setting.. ;D
« Reply #7 on: April 09, 2012, 05:25:39 PM »
Right LG.  if you had enough wind or current you may notice a difference between the course and heading that the unit would show towards a waypoint.  Without these the Course Up and Head Up displays would be the same.
Last post June 14, 2009, 12:14:04 AM
by reso
Last post January 20, 2010, 03:41:58 PM
Last post February 27, 2010, 04:05:06 PM
Last post February 27, 2010, 04:55:57 PM
Last post April 09, 2021, 09:01:09 PM
Last post June 17, 2010, 11:30:24 PM
Last post October 06, 2010, 09:30:20 AM
by Irishrover
Last post August 10, 2011, 10:03:44 AM
by BaitCaster
