Author Topic: Building  (Read 8030 times)
Offline cachristian
  • Unit(s): Helix 10 mega SI
  • Software: latest
Building
« on: March 10, 2012, 11:55:16 AM »
First found wall ~250 long on river channel using 998.  Then building appeared.  Hbird is awesome.
Re: Building
« Reply #1 on: March 10, 2012, 01:38:09 PM »
good image.
What was the depth and and is the side range in meters?
Offline cachristian
  • Software: latest
Re: Building
« Reply #2 on: March 10, 2012, 03:09:05 PM »
36 ft deep.  side range are in feet.
Re: Building
« Reply #3 on: March 10, 2012, 04:37:28 PM »
Great picture and thanks for the depth/feet info.
Have you tried setting contour mode on and eliminate the water column?
http://forums.sideimagingsoft.com/index.php?topic=2089.0
Interesting picture with this setting..
« Last Edit: March 10, 2012, 04:40:06 PM by sonar2000 »
Offline cachristian
  • Software: latest
Re: Building
« Reply #4 on: March 10, 2012, 08:28:11 PM »
I'm going to give contour mode a try.  I'm also going back to record & open in Humviewer.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Building
« Reply #5 on: March 10, 2012, 10:57:20 PM »
Nice clear images. Notice you are running the SI at 1 1/2 times the depth. ( 36 D x 50 SI ). Normally run mine at 3 to 4 times depending what I'm looking for.
Will have to rerun some targets again with the SI dialed in. Thanks for the idea. Just remembered that may work in Humviewer under the " crop to " option.
Last post September 30, 2010, 10:56:26 AM
by mendota
Last post March 04, 2011, 09:29:49 AM
Last post January 14, 2013, 08:33:07 PM
by cachristian
