Author Topic: Tranducer Install on Nitro X5  (Read 8903 times)
Offline basszilla
  • Unit(s): 898c SI & 587ci & 998c HD SI
  • Software: Current
« on: March 01, 2012, 12:07:32 PM »
Hello Forum.    New member here.  Just purchased an 898 unit.  I'm wondering where a good spot to put the transducers would be.  I have pictures of the transom of my boat, but I don't know how to post them.  If anyone has pictures of install on Nitro and is willing to share them, I would greatly appreciate it.  Totally new to Side Imaging.  I do own a 587ci bird without switchfire with a shoot thru hull transducer.  I plan to move that unit to the front of the boat as a trolling motor graph.  Another question I have is the shoot thru hull transducer XP 9 20 T compatible with 898 unit?
Re: Tranducer Install on Nitro X5
« Reply #1 on: March 01, 2012, 01:12:02 PM »
Bass....check the installation section of the media tab..
Use the search tab at the top of the main menu to search for installations on your boat..
There is quite a bit  of help in this forum available for searching...
Offline basszilla
  • Software: Current
« Reply #2 on: March 01, 2012, 03:34:01 PM »
Thanks Chuck!
« Reply #3 on: March 01, 2012, 04:07:36 PM »
The XP-9-20-T transducer you have installed now will work with the 898 unit for the 2D sonar.  You will need to get either the AS-Si-DB-Y transducer splitter cable or a TS3 Transducer Switch to connect it and the HDSi transducer up to your 898 unit.  Most buy the AS-Si-DB-Y cable for this.
Last post March 05, 2011, 12:57:29 PM
by Daniele_Mari
Last post June 14, 2011, 05:04:24 PM
by bigbass
Last post October 10, 2011, 01:07:37 PM
Last post March 06, 2012, 10:54:24 PM
by jtolly
Last post March 16, 2014, 09:29:58 PM
Last post April 16, 2014, 05:03:00 AM
by garm
Last post April 17, 2014, 10:49:57 AM
Last post February 17, 2015, 11:48:42 PM
