Author Topic: boat dock  (Read 8038 times)
Offline agent1953
  • Unit(s): two 798hdsi
boat dock
« on: February 24, 2012, 12:50:44 PM »
hi all
i just bought a second 798hdsi for the front of my boat i also i have the same 798 in the back. when you go past docks and bridge pilings how do they look on screen is my first question. my front one is kind of fuzzy and display is not as sharp as the front one could the two be messing each other up. i did buy the trolling motor transducer did i have to buy that or could i have used the one in the box also this is what i see most of the time on my screen and i know theres something there
Re: boat dock
« Reply #1 on: February 24, 2012, 12:58:35 PM »
My first guess is that maybe your transducer is not level...could you recheck that issue....
Re: boat dock
« Reply #2 on: February 24, 2012, 03:08:08 PM »
How far away is the boat dock from the boat?  You may consider pulling in the Si Range setting.
Is the boat dock floating or does it have any pilings?
What does the same boat dock look like on your other 798ci HD Si and transducer?  Consider swapping them around to see if the problem follows the unit or stays with the transducer.
Re: boat dock
« Reply #3 on: February 24, 2012, 03:48:54 PM »
It looks like the boat dock in on the right as we also seem to be seeing the shoreline.  I have seen this before on a tilted transducer due to the smallness of the boat and the way we had it loaded..
As with any transducer on any boat it needs to be level...
Last post March 23, 2014, 02:20:22 PM
by Dieago
Last post February 28, 2014, 07:51:15 AM
by mako101
Last post March 12, 2014, 01:47:26 PM
by Tjo
Last post April 06, 2015, 11:07:33 AM
Last post September 24, 2017, 10:00:42 PM
Last post November 30, 2017, 12:15:07 PM
by Diesel Pro
Last post February 25, 2020, 04:02:58 AM
by Rüdiger
