Author Topic: ALL SI Models - SI image overlaying the maps  (like low. structuremap)  (Read 8781 times)
Offline crappiejigger
  • Unit(s): pirahna max 20; 798si
Model:
ALL SI Models
Suggested Upgrade:
Explanation:
the Si would be easier to interpret when overlay-ed on your contour map showing you what you've scanned and where. the demo on the lowrance unit i saw really seemed useful .
Added in Software Version:
Comments on Update:
Offline CanyonBay2400
Does Hummin Bird have something like the Lowrance Structure map? I am in the market and looking at the 1198si, but I fish in saltwater and conditions can be rough. So If I could record the structure on a clam day and then when I am out on a rough day I could use the recorded info to overlay my real time sonar data? I prefer the HB over the Lowrance, but can't find where a structure map type product is avail?
The unit comes with a base map.
But, it is not high definition (does not have 1 foot contour lines).
You could record on a calm day.
Then, using PC software, such as Humviewer, review the recordings at
your PC, and note the gps coordinates of any structure you find useful.
As you move the mouse, it will show you the depth and gps coordinates of
the location where the mouse is pointing.
Then, you could create Waypoints by keying those coordinates into your unit,
and giving them Waypoint names.
Or, you could use the PC software HumminbirdPC to add the Waypoints
to an SD card, which will automatically load into your unit's memory
when you put the SD card into one of the card slots.
Then, when you are on the water, whatever map you are using
(base, Navionics, Lakemaster).  The Waypoints would be overlayed
onto your map.
Last post December 05, 2011, 04:11:19 PM
by l889
Last post April 19, 2012, 11:15:50 AM
by albe
Last post September 23, 2012, 10:36:32 AM
by albe
Last post October 01, 2012, 07:33:30 AM
by gros21
Last post September 09, 2014, 10:12:19 PM
by Kenneth_v
Last post November 12, 2014, 08:16:23 AM
by CHOOhonets
Last post July 17, 2016, 10:09:24 PM
by Beaulieu80
Last post October 14, 2024, 10:27:49 AM
by emerles
