Author Topic: 997c si temp problems  (Read 6965 times)
Offline rick555
  • Unit(s): 997c si
« on: January 28, 2012, 10:41:17 AM »
my 997c si temp reads like 123.5 and increases to about 128 degrees as the day warms up. the real temp is in the 40's. I just bought a new transducer with built in temp sensor. this is my second transducer and both are doing the same thing. Any help would be appreciated. Rick
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: 997c si temp problems
« Reply #1 on: January 29, 2012, 12:40:08 PM »
check to see if the offset temp setting hasn't been messed with.
« Reply #2 on: February 01, 2012, 01:31:34 PM »
If the Temp Offset is set to zero than it must be something in the unit.  Call the Humminbird Customer Resource folks to get this fixed. 1-800-633-1468
« Reply #3 on: February 01, 2012, 02:02:18 PM »
It sounds like a unit problem,. I would call the customer support as suggested.  The temperature offset is -10 degrees to +10 degrees so since you are seeing almost a 100 degree deifference then it probably is bad..
Last post June 14, 2010, 11:05:10 PM
Last post October 18, 2011, 06:03:51 PM
Last post February 01, 2012, 05:10:49 PM
Last post May 01, 2012, 12:52:17 PM
by xSilmarilSx
Last post February 27, 2014, 11:35:55 AM
by susieq
Last post April 12, 2014, 04:50:06 AM
by blackberg
Last post July 11, 2014, 08:39:40 AM
