Author Topic: 798 Transducer mounting place  (Read 12765 times)
Offline Staafe
  • Unit(s): 798 HD + HDSI transducer
« on: January 26, 2012, 12:34:35 PM »
I try to find out what its good place install that tranducer, but im not sure what its that best places  :).
Does anyone have some tips  ::)
This is a few pictures my boat transom:
I just remove those ladder
Re: 798 Transducer mounting place
« Reply #1 on: January 26, 2012, 01:04:55 PM »
1st look seems fine.  Only the actual operation in the water will tell.  You might look at the gallery under installations for pictures of where other have put theirs..
« Reply #2 on: January 26, 2012, 02:49:31 PM »
That ladder is going to be a problem no matter where you put the transducer, you are going to get blockage from the ladder in it's current position.  Can it be raised and lowered?
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #3 on: January 26, 2012, 08:16:33 PM »
ladder will need to be in the up position. Test the current location of the transducer and if it works then good, if not, lower it a little bit more. It looks close to minimum clearance.
Offline Staafe
« Reply #4 on: January 26, 2012, 11:25:38 PM »
Yes, I removed those ladder, and I install Lectrotab trim plates the edges of the transom.
« Reply #5 on: February 01, 2012, 12:24:38 PM »
You would want the Compact Side Imaging (CSi) transducer mounted lower than those trim tabs or they will block some of the Si signal.  A current picture of your overall transom would be nice.
Looks like you already have a DualBeam transducer (?) installed on the boat.  Are you going to leave it on your boat?  If not you may want to try installing the CSi transducer there if it will be lower than the new trim tabs.
Offline Staafe
« Reply #6 on: February 01, 2012, 12:53:16 PM »
Yep thats my old dualbeam transducer. I take it off, and install new Si transducer about 5 inch more left, I must re check that place when I have installed trimtabs, and also I gona use this stand
http://navimare.fi/images/lowrance-kaikuanturiteline_1201_058.jpg
Offline Staafe
« Reply #7 on: July 16, 2012, 04:35:38 PM »
Now itīs done  ;D
« Reply #8 on: July 16, 2012, 07:06:39 PM »
I like the track mount so you can adjust it up and down.
« Reply #9 on: July 17, 2012, 09:09:46 AM »
I like the adjustability of that mount too.
Now how about some Screen Snapshots so we can see how well it works?
Get a prop on that motor first though!  ;D
Offline Staafe
« Reply #10 on: July 18, 2012, 10:58:16 AM »
Yep  :). Yes also itīs easy adjust angle, and clean on in the ocean.
Last post September 29, 2009, 07:58:28 AM
Last post March 15, 2010, 10:24:01 PM
by Llunker
Last post April 25, 2010, 04:29:18 PM
by Kickerfish641
Last post April 26, 2010, 02:44:06 PM
Last post March 06, 2011, 08:22:58 AM
by troutfanatic
Last post April 30, 2011, 07:02:34 PM
by djhoffman
Last post March 17, 2012, 10:50:31 PM
by Roddy
