Author Topic: c vs ci designation  (Read 48507 times)
Offline Fay
  • Retirement is the best job I've ever had so far.
  • Unit(s): 798combo, TCR ID-1
  • Software: 7.12
c vs ci designation
« on: January 19, 2012, 09:37:16 AM »
Am I correct in assuming the only units that come with internal antennas are shown with "ci" and all with external are shown with "c" in their names.  thanks in advance - Fay
Re: c vs ci designation
« Reply #1 on: January 19, 2012, 10:43:49 AM »
Not sure of the exact meaning but the C could mean charting capabilities....dont know the exact....but am still checking..
« Last Edit: March 17, 2012, 07:15:01 PM by sonar2000 »
Offline Fay
  • Software: 7.12
« Reply #2 on: January 19, 2012, 10:50:41 AM »
Chuck, it looks like the 798 is the biggest screen available with internal antenna.  Fay
« Reply #3 on: January 19, 2012, 01:00:33 PM »
The “c” designation means that the unit has a color display.
The “i” designation means that the unit comes with an internal GPS Receiver.
If the unit is labeled “ci” than it is a color display unit with an internal GPS Receiver.
Units that are listed as a “Combo” unit means that it is a GPS Chartplotter type unit (shows maps) and that it comes with some sort of GPS Receiver.  If there is no “i” designation; than it comes with an external GPS Receiver.
The 798ci Si and 798ci HD Si units are the only Side Imaging units that we have made with an internal GPS Receiver.
« Reply #4 on: January 19, 2012, 01:16:56 PM »
Where did you find that.  I looked all over the HB site.. ::)
Offline Fay
  • Software: 7.12
« Reply #5 on: January 19, 2012, 01:33:17 PM »
Thanks for the help.  I am surprised that the wider units don't have the internal antenna option.
There are lots of boats with no really good place for an external antenna.  Fay
« Reply #6 on: January 19, 2012, 01:39:11 PM »
Kidneys Chuck… (I’ll have to tell you that joke one day.)
We used to have a FAQ about the unit designations.  Maybe it has been removed or changed.
« Reply #7 on: January 19, 2012, 01:40:57 PM »
It was a good questiion.  Maybe it should be re-added.
dont want to know about your kidneys.... ;D
« Reply #8 on: January 19, 2012, 01:42:49 PM »
Fay,
Most of the folks that buy the Si units like to be able to mount the GPS Receivers as close to directly over the transducer as they can to help increase the marking of waypoints from the sonar Views.  Having the transducer in one location and the GPS Receiver in another will introduce inaccuracies in the waypoints marked when using sonar.
I would also guess that a higher percentage of larger boats that have cabins would have the larger units versus the smaller ones.  If we sold the larger units with internal GPS Receivers than they would have to purchase and mount an external GPS Receiver for the GPS to work.
« Reply #9 on: January 19, 2012, 01:51:19 PM »
This was the best that I could find though it is not the one I was thinking about:
http://www.humminbird.com/FAQ.aspx?ContentId=1870
It was not easy to find either, which means not many others will find it either.
« Reply #10 on: January 19, 2012, 02:10:21 PM »
Is that just for the two units listed or does that description fit all units using a c or ci designation.
My search in FAQ did not get me your results...
Thanks..
« Reply #11 on: January 19, 2012, 04:10:28 PM »
It’s for all of the Humminbird units Chuck.
I searched on “Combo” and then had to look at several of the links listed before finding the one that was applicable.
« Reply #12 on: January 19, 2012, 04:14:36 PM »
Its all about search arguments hehe..... ;D
chuck
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #13 on: January 19, 2012, 06:56:51 PM »
Internal GPS for the larger units would be nice for the open boats. One less item to mount.
Offline Enufzed
  • Enufzed
  • Oh happy days !!
  • Unit(s): 898cx SI
  • Software: V 6.180
« Reply #14 on: January 20, 2012, 01:00:15 AM »
My HB unit is a 898  CX SI ...
Greg Is the " X " for international model or have some other significance?
Thanks in advance
Geoff
« Reply #15 on: January 20, 2012, 08:29:06 AM »
Yes Geoff, the “X” designation means that it is an International model.
« Reply #16 on: January 20, 2012, 10:03:23 AM »
I absolutely don't have any proof of this, but this makes sense to me:
The external gps puck has more surface area to catch
satellite signals with.  You can also adjust the angle, so it sits
flat against the sky.  If you tilt a unit with an internal gps for
better viewing, it may not be the best angle for gps reception.
Since the external puck is pretty large, the receiver is
probably bigger than the internal one.
Also, with the built in gps being so close to the system internals,
you would think that interference could creep in somewhere.
It's my opinion that the external gps would work better than the
internal gps,  but like I said, I have no data to prove it.
« Reply #17 on: January 20, 2012, 10:46:05 AM »
+1 to ITGEEK......good observation.... :D
chuck
Offline Moose1am
  • Unit(s): 898c si
  • Software: 6.610
« Reply #18 on: September 17, 2012, 06:00:56 AM »
I found it a couple of years ago when I first got my new humminbird Unit.  Still it's a good question and should remain in the FAQ section where it's easy to find.
I prefer the external type antenna so that I can mount it as close to my transducer as possible.  I like to have good accuracy in my GPS way points.  I want more accuracy not less.  I like to troll along a certain depth and follow a certain depth contour line on the lakes I fish.  But I find that the map accuracy is off and I may be trolling in 10 ft of water when I  think I'm in 20 ft of water according to my new Lake Master Digital Map.  The real 20 ft depth is 40 ft the other side of the lake.   I don't like hanging up my expensive crank baits in shallow water while I think that I'm in deeper water.  I spent a lot of money getting my crank baits, line counting reels and the Precision Trolling Bible Book so that I can keep my baits in the fish zone and not hung up on shallow water structure.
Regards,
Moose1am
Offline nicko_cairns
  • Unit(s): 798 ci si
  • Software: Latest
  • Accessories: Nope
« Reply #19 on: March 14, 2013, 08:46:58 AM »
Interesting post. Any idea roughly how big the inaccuracies are Greg, or can be?
Fay,
« Reply #20 on: March 14, 2013, 10:20:15 AM »
They can be anywhere up to twice the linear distance between the transducer and GPS Receiver (plus the inaccuracy of the GPS system we are allowed to use).
So if I install the GPS Receiver six feet away from the transducer, when coming back to that same waypoint my transducer could be anywhere up to twelve feet away from the structure I marked – all depending on the heading of the boat when the original waypoint was marked and when I returned to it.
  • Software: Latest
  • Accessories: Nope
« Reply #21 on: March 14, 2013, 11:12:36 PM »
Great good to know thanks Greg, I'm mainly an offshore fisherman so 12' isn't too much of an issue as most rocks/reefs are quite substantial. Cheers.
« Reply #22 on: March 15, 2013, 11:33:42 AM »
Good point Nicko.
Offline geemul
  • Unit(s): 2 x 798cXi SI
  • Software: 7.120
  • Accessories: Ethernet Switch, Minnkota iPilot Link
« Reply #23 on: August 22, 2013, 07:46:51 AM »
Ok, based on the above an 898cx requires an external GPS antenna.
With the latest units having Ethernet along with the Minnkota's having Ethernet can the GPS antenna in the Terrova iPilot be used to supply GPS data to an 898cx via Ethernet?
Thanks,
Geoff
« Reply #24 on: August 22, 2013, 01:44:54 PM »
No Geoff.
Although the Humminbird unit will use the i-Pilot Link's GPS Receiver data for some things, it is not set up to continually use this data for normal GPS operations.
Offline geemul
  • Software: 7.120
« Reply #25 on: August 22, 2013, 07:15:08 PM »
Thanks Greg,
I can see some very good reasons for not doing this anyway.
Geoff
