Author Topic: SI recording to waypoint  (Read 10209 times)
Offline rcc
  • Unit(s): 798 ci HD si
  • Software: 5.8
« on: January 02, 2012, 01:16:07 PM »
When viewing my SI recordings, trying to move my cursor to mark a waypoint from the recording will lock the unit up and the cursor will not move. Is this normal?
Offline Strikeking
  • Unit(s): 798 HD ci si
  • Software: 5.8
Re: SI recording to waypoint
« Reply #1 on: January 02, 2012, 09:36:52 PM »
I am having the exact same problem. Have posted on several message boards with no luck. I have also emailed Humminbird with no response. I plan to call them. I feel that it is a software clitch.
Offline rcc
  • Software: 5.8
« Reply #2 on: January 03, 2012, 01:55:43 PM »
I just submitted an online support request. I'll let you know if I hear anything.
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #3 on: January 03, 2012, 07:42:23 PM »
Have you tried from humviewer?
Offline rcc
  • Software: 5.8
« Reply #4 on: January 03, 2012, 10:00:36 PM »
I just downloaded and tried it. It is excellent. Thanks.
I was using another viewer that needed the file conversion from son to xtf.
Offline LocDown
    • Fishing Videos
« Reply #5 on: January 03, 2012, 11:34:13 PM »
You should be able to make waypoints from the recording from Humviewer.
« Reply #6 on: January 04, 2012, 09:17:14 AM »
I think you will find Humviewer a better viewer than having to convert to xtf viewer.
Martin has been very helpful with his viewer program and it is a good way to review..
You can move around HV much easier than in the unit playback.
And the computer screen is a better picture.
And probably easier to use as humview does not require you to make any conversions...
chuck
« Last Edit: January 04, 2012, 09:18:51 AM by sonar2000 »
Offline rhayes2849
  • I love the water!
  • Unit(s): 789ci si HD
« Reply #7 on: January 16, 2012, 02:04:02 AM »
Hope this helps, I have the same issue...but during playback if you hit the cursor it stops the video from playing, so what I do is press menu and go to playback speed and arrow to the right or left for reverse and then press exit and you can move the cursor and zoom or what ever you like. Also you can not take snap shots when in playback so I turn it off so that I can mark way-points.
posted here http://forums.sideimagingsoft.com/index.php?topic=3388.msg19512#msg19512
Good luck
Last post October 30, 2009, 12:49:25 PM
by pasinomocellin
Last post March 08, 2012, 09:44:29 AM
by albe
Last post March 12, 2012, 02:35:35 PM
by Double Digit
Last post March 31, 2013, 05:27:53 PM
by mdc45
Last post June 02, 2014, 10:22:33 AM
Last post March 29, 2018, 06:01:35 PM
Last post January 29, 2020, 04:22:18 AM
by Rüdiger
Last post January 03, 2023, 07:49:30 PM
