Author Topic: Using video out from console to bow.  (Read 7497 times)
Offline dixonpharmd
  • Unit(s): 898C SI
« on: December 27, 2011, 09:28:59 PM »
Has anyone ever used a video out cable from 898 at console to another unit at bow?
I want to see the exact same image at both spots.
Re: Using video out from console to bow.
« Reply #1 on: December 27, 2011, 09:42:18 PM »
You cannot use the video out to connect 2 HB units.
The video out is for an output to a monitor, PC with video, etc.  If you search this site you should get quite a few hits on using the video out.
Offline dixonpharmd
  • Unit(s): 898C SI
« Reply #2 on: December 27, 2011, 11:11:36 PM »
what kind of monitor will work for this situation?
« Reply #3 on: December 27, 2011, 11:52:53 PM »
you can use pretty much any monitor or TV that has a video input jack on it.....even saw one guy who was playing back his recordings at home with the video out to a 55" TV to try to see things he missed on the water.
Your considerations would include whether the monitor is sunlight visible, is it durable enough to use in a boat, what power is required to power it, etc.
Some have even used a monitor designed for a DVD.
There are some marine monitors designed for this, but they are very expensive.
« Last Edit: December 27, 2011, 11:54:41 PM by Bob B »
Offline Rüdiger
« Reply #4 on: December 28, 2011, 03:37:50 AM »
Hi Dix :D
A second unit via ethernet is probably a better solution than a monitor. The price is about the same, but with a second unit, you have the possibility to change the settings.
mvh
Rüdiger
Finding is better than losing
Offline dixonpharmd
  • Unit(s): 898C SI
« Reply #5 on: December 28, 2011, 08:24:46 AM »
what HB units would be compatible with the 898 via ethernet.  Im looking for something cheaper than another 898.
Offline Rüdiger
« Reply #6 on: December 28, 2011, 08:40:47 AM »
Hi Dix :D
Only 898 and higher via ethernet. :(
mvh
Rüdiger
Last post September 16, 2011, 11:56:46 PM
by HarrisonDawgs
Last post August 04, 2012, 08:55:17 PM
by Roddy
Last post October 02, 2012, 10:09:51 PM
by reddog
Last post February 21, 2013, 10:37:19 AM
by fasteddiemd
Last post July 11, 2013, 10:13:12 AM
by Dave Ervin
Last post August 12, 2013, 05:17:27 PM
by Bizbass
Last post September 22, 2013, 12:49:28 PM
Last post May 04, 2021, 06:59:19 AM
by Kilowatt886
