Author Topic: Importing waypoints to Navplanner2 question  (Read 12367 times)
Offline DRBass
« on: December 17, 2011, 08:47:56 PM »
Not sure what I'm doing wrong.  Waypoints on card can't be read by Navplanner2.  I thought waypoints from Humminbird were gpx files but the ones on my card are something else.  HMR files?
Waypoints are from an 1197 via SD card.  I've tried saving them from Humminbird PC to the card as well.
Any ideas?
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: Importing waypoints to Navplanner2 question
« Reply #1 on: December 18, 2011, 06:55:02 PM »
Q. What do I need to transfer routes and waypoints from my PC to my chartplotter?
A. After installing NavPlanner software and your Navionics Multi Card Reader, all you will need is a blank SD or CF media card (depending on which fits into your chartplotter) to save and transfer your routes and waypoints to and from your PC and chartplotter. Once saved, insert this memory card into your chartplotter and upload your new routes and waypoints. After upload is complete, insert your Navionics Chart card into your chartplotter; the routes and waypoints you created and uploaded will now appear over the Navionics Chart information. The Quick Start Guide included in your packaging provides step-by-step instructions for installing and using NavPlanner. Please also see our downloadable Users Guide for more information
« Reply #2 on: December 19, 2011, 01:54:19 PM »
Gary,
I think that DRBass is trying to go in the opposite direction with his waypoints and get them from his 1197 to the NavPlanner2 program.
« Reply #3 on: December 19, 2011, 01:55:41 PM »
Any ideas?
DRBass,
Try this:
1.  Export the waypoints in your 1197 unit to the SD card.  The waypoints are in a file named DATA.HWR and will need to be converted to the *.gpx file format so that you can use them.
2.  Install the SD card in your computer and use the “Download” in HumminbirdPC option to move a copy of the waypoints into HumminbirdPC.  The HumminbirdPC program will than convert and name the waypoint with a date code but they will be in the *.gpx file format now.
3.  Use the File > Save As… option to name and save the *.gpx file somewhere on your computer so that you can try opening it with the NavPlanner2 software.
Offline DRBass
« Reply #4 on: December 19, 2011, 02:27:52 PM »
Thanks,
I think I've figured it out.  Basically did what you said instead of trying to take the file off of the card.  Just took it off my hardrive where it is saved under "HumminbirdPC"
I've got over 1300 waypoints I need to go through and organize.
« Reply #5 on: December 19, 2011, 02:39:14 PM »
That works DRBass.
The key is just to get a copy of the data after the HumminbirdPC program converts it to the *.gpx file format.  Many think that just because they can see it in the HumminbirdPC program that it automatically converts it on the memory card.  It doesn’t, so I always recommend performing a Save As… to somewhere on the computer that you can find it.
Last post August 27, 2010, 06:36:43 PM
by ETnSC
Last post February 12, 2011, 12:46:39 PM
Last post April 10, 2014, 12:45:25 PM
Last post June 30, 2012, 11:35:38 AM
by Brenardo
Last post August 11, 2012, 05:24:50 PM
Last post January 11, 2013, 11:10:23 AM
Last post October 11, 2014, 08:24:23 PM
by Colt45
Last post June 22, 2015, 12:34:03 AM
by Typhoon
