Author Topic: Readouts Incorrectly Displayed?  (Read 9928 times)
Offline slabomania
  • Unit(s): 798c si, 788c
  • Accessories: Interlink
« on: October 29, 2011, 05:18:10 PM »
I have a new 998c si unit which displays the incorrect readout in some of the locations.  For instance, it is set to temperature in the "Select Readouts" of the menu option but displays speed.  Any ideas?
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: Readouts Incorrectly Displayed?
« Reply #1 on: November 01, 2011, 09:52:39 PM »
were you in the naviation/map mode? ..I have found that some readings are different depending on the screen but should be correct in 2d sonar mode.
Offline raricker
  • Unit(s): 797c, 998c
  • Software: 5.450, 6.490
  • Accessories: weathersense, aux speed,GRHA
« Reply #2 on: November 02, 2011, 10:38:03 AM »
Hi,
I noticed the same thing when I got my 998c. I was about to fire off a problem ticket until I looked at the Owners Manual for clarification - see page 128. I'm guessing this "feature" is a carryover from the older (Matrix based) Legacy boxes. It probably works that way to maintain "product consistency"? Just a guess.
Take care,
Roger
Offline benamen
  • Unit(s): 997C SI
  • Software: 4.75
  • Accessories: none
« Reply #3 on: November 02, 2011, 06:49:27 PM »
When I started to use my 997 a year ago, I had the same problem. I did a reset to factory defaults and set the read out the way I wanted and then did another check. Probably took 3-4 resets before I had the readouts the way I wanted.
Offline slabomania
« Reply #4 on: November 22, 2011, 06:00:21 PM »
Yes, each screen is different.  Some of the screens will show the speed twice, etc.
« Reply #5 on: November 23, 2011, 10:14:49 AM »
It was a lot easier when a product manual shipped with the unit. But the economy and social networking has business bottom line a big issue in pricing.
For those of you with computers I would strongly advise downloading the manual, or if you have a disk loading that to your computer.
Important pages that are mostly referenced you can print out.
Some print shops may not charge you very much to print the manual from disk..
At least, for now, HB does offer you the ability to readjust your views somewhat in a format you like..
Offline jgollihar
  • Unit(s): 1197, 998
  • Accessories: interlink
« Reply #6 on: December 09, 2011, 09:47:21 PM »
I have noticed that even if I turn readout 2 off, the course will still be displayed in any navigation view.
« Reply #7 on: December 12, 2011, 01:29:21 PM »
That is normal for that View jgollihar.  The unit is programmed to display the Course in that position when in the navigation view.
Last post July 13, 2010, 04:04:27 AM
by legend
Last post April 26, 2010, 05:38:34 PM
Last post June 24, 2010, 02:11:40 PM
by bishoptf
Last post January 07, 2015, 07:53:53 PM
Last post April 16, 2012, 10:48:52 PM
by Shooter00
Last post June 15, 2014, 04:35:32 PM
by Gattlin
Last post March 13, 2013, 04:09:48 PM
Last post January 31, 2017, 08:11:45 PM
by October1
