Author Topic: Yellowfin software  (Read 24567 times)
Yellowfin software
« on: October 23, 2011, 01:09:04 PM »
I want to try the Yellowfin software for viewing sonar recordings.
The link on this site to install the software doesn't work on my computer.
I see on the www.imagenex.com site that I'm supposed to contact them
at imagenex@shaw.ca.
I was wondering if anyone knows how much the software costs and
if the updates cost anything.
Thanks in advance.
Re: Yellowfin software
« Reply #1 on: October 23, 2011, 01:41:38 PM »
YellowFin does not recognize the HB files.  The converter was written by a certain person who broke into the code...
Install the YF program and use the HBSI converter to make HB files available to YF.....
ITG   what computer type do you have?
YF works on all of our computers..Even the windows 7...
« Reply #2 on: October 23, 2011, 02:04:09 PM »
Chuck,
I'm using Windows XP.
I downloaded and installed the HBSI converter Ok, but the Yellowfin doesn't install.
« Reply #3 on: October 23, 2011, 04:50:52 PM »
OK.  One of our computer is the XP and yellowFin installed and ran ok...
We have it on Win2000, XP, Vista and win-7.....
It is possible to remove the attemp and try a new download and install.
Does it give an error or what happens when you try the install...
I think you have to do the install and then do each upgrade.  (2 of them)
« Last Edit: October 23, 2011, 04:52:02 PM by sonar2000 »
« Reply #4 on: October 24, 2011, 07:28:09 AM »
Chuck,
It says something about DOS or 16 bit  needs to be loaded.
« Reply #5 on: October 24, 2011, 11:57:19 AM »
OK....not sure about that........On XP I thought the 16 or 32 bit was ok.....This is strange...Let me look over the XP a bit closer....
« Last Edit: October 24, 2011, 12:04:22 PM by sonar2000 »
« Reply #6 on: October 24, 2011, 12:05:48 PM »
ITG....I looked at the XP computer and it has the 2.011 level of YF which is the latest....I remember installing YF and then as each upgrade came out I put it on...
Dont know about this...
« Reply #7 on: October 24, 2011, 12:26:56 PM »
Thanks for checking Chuck.
I've contactd imaginex to see what it will take to get the software.
« Reply #8 on: October 24, 2011, 12:56:45 PM »
Hopefully they can make it work.  We use YF a lot...
Let us know of any fix...
« Reply #9 on: October 25, 2011, 07:15:33 AM »
Here is what I got from Imagenex:
Quote
We have not given permission to anyone to distribute the YellowFin software for any equipment other than the YellowFin system. It is not intended to be used on any hardware other than the YellowFin System. We do not support or troubleshoot Humminbird sonars and I think it would be best to direct any technical questions you have directly to them.
Bummer.
« Reply #10 on: October 25, 2011, 08:46:35 AM »
Yes that is true.
However.  Prior to loading any data the YF program must install and I dont think that HB has any control over the install program. YF needs to step up to that..
Once the prog loads then the issue is whose data will you ask for it to open. That is where the HBSI converter comes into play.
Since the YF program is on this thread I dont know if a license is required to speak with them in detail..
I would call YF back one more time and ask abut the pure base install. If they ask how you got the program then they may not support you......
I still dont know why it does not install as it is on several XP systems that I know of..
Of course we have it on XP, Vista and Win-7...
« Last Edit: October 25, 2011, 08:48:55 AM by sonar2000 »
Last post October 27, 2011, 08:24:14 AM
Last post May 13, 2009, 07:03:27 PM
Last post March 28, 2010, 07:36:44 PM
Last post December 25, 2010, 06:25:15 AM
by Drifter
Last post October 28, 2011, 03:31:56 PM
Last post May 30, 2012, 03:45:19 AM
by Rüdiger
Last post February 12, 2014, 07:35:34 PM
Last post March 06, 2014, 12:23:52 AM
by MT-ED
