Author Topic: HumViewer and Google Earth  (Read 17874 times)
Offline Carl
  • Unit(s): 798ci SI
  • Software: 4.620
« on: August 17, 2009, 06:38:16 AM »
I'm trying to go to google earth from the humviewer menu and it will not open.  It will go to google earth but then it just stops at the opening page.  I tested my other programs to see if they would access google earth and they did.  Any suggestions?
Re: HumViewer and Google Earth
« Reply #1 on: August 17, 2009, 04:10:56 PM »
robert may have more on this, but check your level of Humviewer.  I am at 3.031 and Google works fine.  Chuck
Offline Carl
  • Unit(s): 798ci SI
  • Software: 4.620
« Reply #2 on: August 17, 2009, 07:01:06 PM »
Im at 3.031 also.  I notice that I can open google earth by clicking on the export file but cannot through the program.
« Reply #3 on: August 18, 2009, 02:49:50 PM »
I open in Google from the tool bar.  I think the export is to something like excel or another program.   Did you try the tool selection to Google?   chuck
« Reply #4 on: August 18, 2009, 03:17:15 PM »
OK, I did an export to a file on my hard drive.  I then went to the hard drive file and clicked on the saved file.  Google Earth opened the file ok.   I did this several times and it worked allright..  I am using windows XP SP3. not sure I am of any help at this point as it works here.  Maybe some other computer person may know of what to do.  Chuck
Offline Carl
  • Unit(s): 798ci SI
  • Software: 4.620
« Reply #5 on: August 18, 2009, 03:28:06 PM »
I can open it from the exported file (Klm file).  It will not open if I try to open it from the menu bar inside the program with a loaded file running containing waypoints.  When I try to open it from the program it goes to google earth but it freezes up at the preview window (Helps and hint window).  I may try to upgrade to 5.0 to see if this helps.  I dont think I'm running this version now.
« Reply #6 on: August 18, 2009, 04:35:45 PM »
I loaded it to google ok from inside the program while it was running.  I also had waypoints.  My 1197 is at 5.0x
Dont know what to try since mine works.  maybe someone else can help.  Chuck
Offline Carl
  • Unit(s): 798ci SI
  • Software: 4.620
« Reply #7 on: August 19, 2009, 10:48:03 AM »
I updated to google earth 5.0 and it works great.
Thanks for all the input.
Last post January 12, 2011, 09:47:41 AM
by terry0540
Last post August 09, 2011, 11:01:37 PM
by Further North
Last post August 09, 2011, 11:00:03 PM
by Further North
Last post February 13, 2013, 01:47:49 PM
by staoB regnaR
Last post May 26, 2013, 10:35:39 AM
Last post August 06, 2013, 11:25:51 AM
Last post January 10, 2014, 01:27:56 PM
by JoeH
Last post June 28, 2017, 02:19:03 PM
by leeland
