Author Topic: Works the 898CX SI with 2 sonar on a Y-cable  (Read 7032 times)
Offline Wylezalek
  • Zander-Fanatick
  • Unit(s): Humminbird 998cx-798c US
  • Software: 6.180-5.840
  • Accessories: Wetersene sandisk extr-32gb 16gb 8 gb
« on: October 09, 2011, 08:16:27 AM »
Hello.
Works the 898CX SI with 2 sonar on a Y-cable. If it works, which the sonars?
Thank you.
Best Regards
Peter
Hello my hobby is a perch and his methods of fishing, Se Id Imagging Humminbird Forum, my passion is hunting for a record perch ,greet colleagues from our Humminbird forms.
Re: Works the 898CX SI with 2 sonar on a Y-cable
« Reply #1 on: October 10, 2011, 10:43:01 AM »
Which two transducer and Y-cable are you wanting to know about Peter?  There are two different possibilities here:
1.  The Y-cable that uses the Si sonar and water temperature from the Si transducer and the 2D sonar from a DualBeam transducer.  This is the AS-Si-DB-Y cable.
2.  The Y-cable that uses the Right Si sonar, 2D sonar and water temperature from the Starboard side mounted Si transducer and the the Left side Si sonar from the Port side mounted Si transducer.  This is the AS-Si-LR-Y cable.
Last post December 19, 2009, 10:13:47 PM
by capttim
Last post December 07, 2010, 10:06:43 AM
Last post July 13, 2013, 06:51:56 AM
Last post June 24, 2013, 04:01:41 PM
Last post May 27, 2014, 01:44:59 PM
Last post February 27, 2015, 08:42:43 PM
Last post June 04, 2016, 08:01:06 PM
Last post March 04, 2018, 02:15:08 AM
by iceperch
