Author Topic: 797c2 si registered user change?  (Read 12347 times)
Offline jagert59
  • Unit(s): 997c si, 797c2
« on: August 26, 2011, 02:02:45 PM »
Bought a used 797c2 si and obviously when I power it up it displays the previous owner's name.  Is there any way to change this?  Thanks
Re: 797c2 si registered user change?
« Reply #1 on: August 26, 2011, 02:51:56 PM »
Yes...hang on a minute and i will get the procedure.
« Reply #2 on: August 26, 2011, 02:55:24 PM »
Jolly Roger posted this in the FAQ's..
Here is the link to it..
It is easy to change or modify..
http://forums.sideimagingsoft.com/index.php?topic=719.msg3345#msg3345
« Last Edit: August 27, 2011, 12:28:30 PM by sonar2000 »
Offline jagert59
« Reply #3 on: August 26, 2011, 09:35:46 PM »
Thanks, I give it a try tommorrow!!!
« Reply #4 on: August 27, 2011, 12:29:39 PM »
Great.....let us know if you have any trouble...........Chuck
Offline jagert59
« Reply #5 on: August 29, 2011, 07:46:49 PM »
Took me a little longer to get around to it, but worked great!  Will this work for my 997csi also?  Thanks again!  Tom
« Reply #6 on: August 30, 2011, 01:48:36 PM »
You could or you could just use the HumminbirdPC program:
1. Insert the SD card into your computer’s SD card reader.
2. Start up HumminbirdPC.
3. Select the SD memory card icon on the left side of the screen.
4. Select the Green button with the “A b C” on it.
5. Type in your preferred text in the allowed areas.
6. Press the “Save” button.
7. Disconnect the SD card from your computer.
8. Install the SD card into your Humminbird unit.
9. Power on your Humminbird unit and it should automatically load the profile data changes.
Last post January 15, 2010, 04:41:19 AM
Last post March 12, 2010, 04:02:44 PM
by soretoe
Last post September 10, 2010, 05:46:50 AM
by Sakai
Last post January 28, 2011, 01:15:49 PM
Last post April 15, 2013, 12:20:06 PM
Last post May 12, 2014, 01:01:42 PM
Last post March 29, 2017, 09:11:09 PM
Last post November 24, 2017, 10:34:53 PM
