Author Topic: Can I bring the unit in the house to perform upgrades?  (Read 8286 times)
Offline Bossman
  • Unit(s): 898cSI
  • Accessories: GPS
« on: March 17, 2011, 11:32:43 PM »
Hi , I was wondering if you can bring the 898cSI into the house and connect directly to the PC for updates?
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: Can I bring the unit in the house to perform upgrades?
« Reply #1 on: March 18, 2011, 05:01:20 AM »
Yes you can. Gary
« Reply #2 on: March 18, 2011, 09:51:53 AM »
You will also need the cable to connect the unit to the pc....Chuck
Offline lacdubonnet
  • Unit(s): 797C2, 987C SI
« Reply #3 on: June 07, 2011, 12:40:09 PM »
If you have 2 units, can you put the software for both units in the same SD Card?  Will the units know the difference?
Also, I have seen that I should use a smaller SD card for updating programming on the units?  Is this right?
« Reply #4 on: June 07, 2011, 12:51:22 PM »
I would not do this as we have had some reports of this not working correctly.  I would only have the single software update needed for one unit at a time on the memory card.
A smaller memory card can be used as the updates are not that large.  I still use a 16MB MMC card (don’t laugh as it still works!) to update my units.
« Reply #5 on: June 07, 2011, 08:07:31 PM »
Definately only put on one update at a  time on an card.
The unit loading can get quite confused if a particular update is on the card that is not for the unit...
Last post April 02, 2009, 12:21:23 AM
Last post July 07, 2012, 11:18:02 PM
by PingMe
Last post July 02, 2013, 01:59:18 PM
Last post October 21, 2013, 10:38:26 AM
Last post May 07, 2014, 10:42:26 AM
Last post September 18, 2014, 08:58:54 AM
by fishermanatr
Last post November 03, 2016, 02:08:56 PM
Last post February 07, 2019, 04:34:22 PM
