Author Topic: How is DI effected by the movement of a trolling motor?  (Read 3562 times)
Offline ctf58
  • Unit(s): 570 DI
« on: August 10, 2011, 12:36:01 AM »
I mounted my 570DI on the bow. Now I'm wondering since the beam is a narrow, not circular, How does the rapid movement of a trolling motor turning effect the image? I just figured I'll be fishing from the front so I put the best sonar on the bow I could afford. I have a HB141 on the dash.
I'm new to the DI scene, did I mess up by putting it on the bow?
Re: How is DI effected by the movement of a trolling motor?
« Reply #1 on: August 10, 2011, 08:56:41 AM »
No you did not mess up.  but remember that sonar is a directional beam. Turning the trolling motor will redirect the beam and not give a good display as with a straight line.
But remember this on DI, you are looking directly under the transducer so your immediate picture is true.  If you are recording and playing back then the bottom might not be as depicted..
Especially if using an external viewer.
Offline kosmo
  • Unit(s): 2 - 998 , 597hd/di
« Reply #2 on: August 10, 2011, 11:31:10 AM »
you did the right thing putting  on the trolling  motor in my opinion .l use mine there.looks really good even when turning the rolling motor :)
Last post August 28, 2009, 08:20:25 AM
Last post October 23, 2009, 10:33:41 AM
Trolling Motor Choke
Started by Wayne P. Accessories
Last post August 23, 2010, 04:47:34 PM
Last post May 25, 2010, 08:00:00 PM
by Jason Hoerter
Last post April 24, 2012, 12:01:35 AM
by Gattlin
Last post September 07, 2010, 09:32:38 PM
Last post March 18, 2011, 06:27:53 AM
by SaminVa.
Last post March 03, 2011, 02:41:25 PM
