Images, Snapshots and Videos
General Pictures and Screen Captures
Topic:
chesapeak bay
« previous
next »
Print
Pages: [
Go Down
Author
Topic: chesapeak bay (Read 9313 times)
wizzo86
Full Member
diving in phillapenes
chesapeak bay
on:
August 02, 2009, 01:18:41 PM »
from yesterday while fishing under the bay bridge. This image is a definate future dive shght. it is about 300' south of the bridge
Logged
Jolly Roger
Hero Member
HB Addicted
Unit(s):
HELIX 9 G3N, 998Cx SI, 959DI
Software:
latest (mostly)
Accessories:
AS GR50, custom towfish and: A boat!!
Re: chesapeak bay
Reply #1 on:
August 03, 2009, 08:17:30 AM »
Hi Wizzo,
now I even know how the bottom at the bridge looks like
I drove underneath the bridge in 1992, when I had the chance to take a trip from Rudee's Inlet to Norfolk Harbour. What a ride!
Best wishes
Harry
Logged
YES,......
WE SCAN!
wizzo86
Full Member
Re: chesapeak bay
Reply #2 on:
August 03, 2009, 12:26:10 PM »
thanks harry
This is the bridge between the eastern shore and western shore near annapolis. Your thinking of the bridge tunnel from maryland to virginia. In the pic you can see a couple squares to the lower left. that is the bridge pilings the object to the right is the one i want to dive. It's about 300 feet south of the bridge. Looks like a wreck to me. They use to wire drag wrecks that posed a hazard to navigation to get them broken up. I'm suspecting that is the case here. Seems to be too far from the bridge to be construction debre.
Logged
wizzo86
Full Member
Re: chesapeak bay
Reply #3 on:
August 03, 2009, 12:40:30 PM »
here is another capture. This one i'm not sure what it is. It looks like a wreck that is maybe flat to the bottom. There is alot of mud an muck.
Logged
wizzo86
Full Member
Re: chesapeak bay
Reply #4 on:
August 03, 2009, 12:46:11 PM »
This one you can clearly see to the mid lower right the base for one of the bridge supports.
There was alot of boat traffic out and the boat was rocking as you can see. Wish i could figure out how to put the transducer on a tow fish.
Logged
wizzo86
Full Member
Re: chesapeak bay
Reply #5 on:
August 03, 2009, 12:50:44 PM »
This one you can see two types of supports on the upper and lower right.
Last Edit: August 03, 2009, 12:53:36 PM by wizzo86
Logged
Jolly Roger
Hero Member
HB Addicted
Unit(s):
Software:
latest (mostly)
Accessories:
Re: chesapeak bay
Reply #6 on:
August 03, 2009, 02:03:01 PM »
Cool shots Wizzo,
but rocky seas as it looks like.
You're right, I meant the Bridge further South.
The object which looks like a wreck on your first picture is worth to be further investigated. The tipped end is quite characteristic for a wreck which is sunk into the mud. Let us know what you find out about it.
Regards
Harry
Logged
YES,......
WE SCAN!
wizzo86
Full Member
Re: chesapeak bay
Reply #7 on:
August 16, 2009, 02:53:46 PM »
Here is a capture taken yesterday while trying to find a sunken barge. I need to bone up on my go to optionfor way points, To be able to find an exact locsation marked... This is a channel marker. You can see the chain in the middle left. I think all the other stuff is from current around the base. Did not dive yesterday.
Logged
salvor6
Jr. Member
Pirate of the Martires
Unit(s):
1198c Si Combo
Software:
6.64
Re: chesapeak bay
Reply #8 on:
April 18, 2010, 01:49:03 PM »
My buddy mounted his Humminbird on a jet ski. Here is a pic with the PVC towfish he made.
Logged
sonar2000
Chief
Global Moderator
It is not lost ...it has been misplaced.
Unit(s):
(1) 1197 (1) 1198
Software:
6.6
Accessories:
Tow Fish
Re: chesapeak bay
Reply #9 on:
April 18, 2010, 03:50:45 PM »
Wizz, I see your concern for a towfish. Cheaper might be to lower the transducer instead of towing. Lowering can be done by mounting the ducer on a trolling motor shaft (standalone and using a mount especially for the shaft. (johnny ray ) makes this mount. We use a 6 foot shaft on ours and on the water with waves we can put the transducer about 3 feet under water. Makes the picture clearer. You can build a bracket to hold the shaft and make it adjustable. this will take the lines out of the pictures you posted.
Some of the pictures do show the effects of wire dragging.
The bridge piers are a good spot to look for fish also. So nice that HB has the SI to show this structure.
Logged
sonar2000
Chief
Global Moderator
Unit(s):
(1) 1197 (1) 1198
Software:
6.6
Accessories:
Tow Fish
Re: chesapeak bay
Reply #10 on:
April 18, 2010, 05:30:40 PM »
SI shows some great pictures. Here is a 4 x 4 concrete block 2 foot high used for a dock anchor.
You can see where the block was dragged during a high wind storm.
Logged
Print
Pages: [
Go Up
« previous
next »
Smf
Topic:
chesapeak bay
