Author Topic: magnetic field influence / Transducer  (Read 15601 times)
Offline tomhigher
« on: July 25, 2009, 06:27:52 AM »
Hello,
i want to mount the transducer via an magnetic plate on my boat. Is this an problem, because the transducer will not work
under the influence of an magnetic field ?  ::)
regards,
TOM
Re: magnetic field influence / Transducer
« Reply #1 on: July 25, 2009, 02:25:43 PM »
I have no idea Tom.  I don’t think that it will harm the transducer but I certainly would keep that magnet away from the unit itself!
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #2 on: July 26, 2009, 03:02:24 AM »
What sort of magnet do you want to use Tom?
Propably some strong magnet like the "Seasearcher" (http://www.nauticalia.com/uk-info/products_in_action/sea_searcher_recovery_magnet/3101.html)?
My feeling is that it shouldn't affect the transducer from the electrical side as long as it is a static magnet that doesn't change its magnetic field.
As Greg already mentioned: Since it has to be a very strong magnet to keep the installation in place, keep it away from the unit head. That might hurt the interior electronics of the unit.
Good luck
Harry
YES,......
WE SCAN!
Offline Kimi
  • Unit(s): 798CXI 898 CXI
« Reply #3 on: February 19, 2010, 03:22:15 PM »
Does the magnetic field have any influence on the signalquality?? Maybe a very stupid question, but when I have been scanning an specific area of the seebed, I get poor signal/picture quality. The ground in this area is full of iron and its wery magnetic. The compass gets really wild in this region, turns over 90 degrees. Thers also an closed ironmine under the seebed. So there is wery strong magnetic fields.
Just wonder.. ::)  Kimi..
homepage: ( in Finish only) www.wreckdiving.yolasite.com
« Reply #4 on: February 19, 2010, 03:43:26 PM »
there are transducer suction cups just for tempory mounting.  I have two of these and each works fine.  even in higher speeds.  chuck
Last post June 13, 2009, 03:44:25 AM
Last post April 06, 2009, 04:39:12 PM
Last post May 19, 2009, 05:08:38 PM
by inshorecatch
Last post July 08, 2009, 09:35:07 PM
Last post October 19, 2009, 07:19:47 PM
Last post March 02, 2010, 09:55:50 AM
Last post January 17, 2013, 02:41:53 PM
by navionic
Last post April 29, 2020, 10:20:39 PM
