Author Topic: Test run with new unit, no down image  (Read 13178 times)
Offline corey4x4man
  • Unit(s): 798ci HD si
« on: June 01, 2011, 04:19:14 PM »
So here is a short clip i got on my test run out for the first time. I though I was recording for about 5min but the vid is really short.
1: how does my settings look for the side imaging?
2: I was able to see the down imaging but does not show in Viewer
3: any recommendations?
Re: Test run with new unit, no down image
« Reply #1 on: June 01, 2011, 05:50:48 PM »
Look at the recorded scan and check the file associated with the .dat name.  open that file and see if the b000 thru b003 all have the same size .SON file size...
Also try in humviewer just the left top selection and see if any thing shows on the screen..
But do check that .son files sizes...
Offline corey4x4man
« Reply #2 on: June 01, 2011, 06:09:24 PM »
all 3 files are 3kb..... and nothing when only use top
« Reply #3 on: June 01, 2011, 06:18:11 PM »
you should have 4 files. b000, b001, b002 and b003.............
stand-by a sec...
The b000 and b001 should be in general about 1/2 the size of the b002 and b003.
« Last Edit: June 01, 2011, 06:27:47 PM by sonar2000 »
« Reply #4 on: June 01, 2011, 06:30:20 PM »
Corey, when in humviewer point your cursor to the left screen and right click on it.  Click the view selection...
Select the 2d down or the down imaging (455)
then go back to the play button..
Offline corey4x4man
« Reply #5 on: June 02, 2011, 09:04:28 AM »
Ok so i have no b000 file may be the cause.
And Yes I do understand how to select the views i want but the files are not there.
« Reply #6 on: June 02, 2011, 10:32:52 AM »
I think the b000 is the 83 hertz.  might check on your unit to see if you have selected that freq..
I will take a file and delete the b000 and see what humview does...
Get back to you shortly....... :P
« Last Edit: June 02, 2011, 01:25:36 PM by sonar2000 »
« Reply #7 on: June 02, 2011, 10:56:21 AM »
OK deleted the b000 and humview runs with a 200 khz 2down or a 455 down image in the left screen. I dont see a selection on the view tab for 83khz.....
Have you tried a record that contains a b000?
Also do you have any other recordings.
I am lost right now on this one...... :P
Offline corey4x4man
« Reply #8 on: June 02, 2011, 12:55:01 PM »
yea i can see the sample one just fine thats why im confused.  Im sure its something my unit is not recording for some reason but then again i could look at the recording on my unit and can view the down image...??.....
This was my first recording, i will be takin the boat out this weekend and will play with it
« Reply #9 on: June 02, 2011, 01:24:24 PM »
OK.  make several runs and then see if any have the b000......
Not sure here yet...lets see what happens on the next run....
check you sonar menu tab for beam select.  See if you have set the 200/83 beam.
Dont know if this has any bearing on the problem but it might be worth a check....
We are running the 1197 .....
Roddy, which units do you have..., Gary or George???????
« Last Edit: June 02, 2011, 01:32:44 PM by sonar2000 »
Last post June 20, 2009, 11:49:03 AM
Last post March 20, 2010, 05:37:59 PM
by twobearlake
Last post July 04, 2010, 01:31:49 AM
Last post May 08, 2011, 10:15:52 PM
by Roddy
Last post July 02, 2011, 10:49:30 AM
by calli1
Last post July 20, 2011, 11:11:02 AM
Last post August 20, 2011, 01:41:11 AM
by kosmo
Last post May 22, 2023, 06:25:46 PM
by danlaboucane
