Author Topic: Interlinking a 998 too 958  (Read 6172 times)
Offline bigbassbuck
  • Unit(s): 998SI & 747c
  • Accessories: Interlink
« on: April 22, 2011, 08:21:29 PM »
If I interlink my 998 at the console too 958 on the bow will the same gps chart from the 998 view be on my 958,,and do I have too hook up the puck to the 958 or can they share one puck??? and do I have too buy another hotmap chip for the 958
Offline ffmedic147
  • Unit(s): 998cnvb 958cnvb
  • Software: Whatever Works
  • Accessories: ethernet cable
Re: Interlinking a 998 too 958
« Reply #1 on: May 10, 2011, 06:16:56 PM »
Thisis my expeirence. i hooked the same units upto my interlink. You can use one puck (i didnt but you can) also u do have to get one chip for each you can not share topo screens. Aleast thats what i found out. thats why i got both mine with nvb.
« Reply #2 on: May 11, 2011, 12:49:33 PM »
ffmedic147 is right: one map card for each unit as the maps cannot be shared and you can use only one GPS Receiver.
If it were me though I would use the Ethernet connection between the 958 and 998 units and connect a GPS Receiver to each unit.  Although you can share the GPS Receiver between the units you should use the one connected to the unit and it should be mounted as close to the transducer that unit is using so that your waypoints will be more accurate.  Having the second GPS Receiver also gives you a backup in case one quits working in the middle of a fishing trip.  The Ethernet cable also costs less than the InterLink.
Offline ffmedic147
« Reply #3 on: May 12, 2011, 09:36:11 AM »
I will be switching mine to ethernet as soon as the units get back to me. I have no need for the interlink.
Last post March 29, 2012, 08:46:18 AM
Last post August 22, 2012, 03:18:37 PM
by Roddy
Last post March 05, 2013, 04:47:50 PM
Last post April 29, 2013, 03:23:34 PM
by maxfli
