Author Topic: Hey Greg  (Read 9516 times)
Offline FlatsFokker
Hey Greg
« on: April 22, 2011, 10:10:02 AM »
As soon as I get your response it's time to order ;D
But  I do have a few questions for you before I do.
 As far as dead rise goes....at what point do I need the 14 degree ducer? My Key West has a 19 degree dead rise..should I stick to the standard shoot through hull ducer? And as far as slaving another unit to the 898 goes..would I have to go with the 798ci HD SI  for my side imaging to function on the bow unit?
And at the risk of being redundant,I want to go over my shopping list one more time.
898c Si
2nd. unit????
XP-9-20 Ducer or the 14 degree ducer?
AS-Si-DB-Y For high speed ducer.
And an ether net cable to slave sec. unit to 898?
Offline FlatsFokker
Re: Hey Greg
« Reply #1 on: April 22, 2011, 11:09:13 PM »
898c Si
2nd. unit????
All right, no response? So be it.
Re: Hey Greg
« Reply #2 on: April 23, 2011, 12:28:27 PM »
Note to the posting:
Greg is not an everyday user and donates his time. I know you may be a bit pushed to buy but if you need his immediate help, then go to his profile and send him an e-mail.
Other folks can also answer question(s) if you ask specifically a question.
Some of the information you are looking for may already be in this forum and by using the search tab at the top of the main menu you might find additional answers while waiting for Greg to sign in.
There is a lot of talent in this membership who can bring a whole lot of information and experience to this thread and may also weigh in on your need.
« Last Edit: April 23, 2011, 12:33:56 PM by sonar2000 »
Re: Hey Greg
« Reply #3 on: April 23, 2011, 12:48:40 PM »
FlatsFokker,
As Newkid4si stated, Greg volunteers his time here when he can.  There are many qualified people here who could answer your question as well, but since you directed it to Greg, no one else chose to answer yet.
As far as your deadrise, the 14 deg would be best if you do not have a flat spot or a spot near the V that will let you shoot straight (or near straight) down.  You can build up the epoxy under one side slightly to compensate, but just make sure you do not over mix it and get any air bubbles.
I think you would be just fine with the 14 deg and just mount it normal.  The angle of the cone is great enough that you will still be getting most of the beam straight down.
If you could post some picts of your transom and a few shots inside the hull where you propose to mount the transducer, we may be able to give you a little more guidance.
Thanks,
Last post September 28, 2010, 06:11:21 PM
Last post October 14, 2010, 04:42:06 AM
by Doug Johnston
Last post November 16, 2010, 09:02:01 AM
Last post August 12, 2011, 09:25:00 AM
by jimf
Last post September 28, 2011, 01:28:01 PM
Last post September 04, 2012, 05:28:21 PM
by BCLII
Last post March 11, 2014, 10:56:58 AM
Last post March 21, 2014, 11:16:42 AM
