Author Topic: Humminbird recording side imaging problem  (Read 15523 times)
Offline geggen
« on: April 09, 2011, 08:43:47 AM »
How can i record side scan searches to the sd card on my humminbird 987?   i have the latest software.
But i havent found out how to record to the sd cards
Re: Humminbird recording side imaging problem
« Reply #1 on: April 09, 2011, 10:20:05 AM »
Set the unit from the main menu to advanced mode..
To make side image recordings;
Go to the menu for recordings (it should be the last on the right) and then select start recording when you want to stop go back to the menu and select stop recording.
Do you have the handbook or the Cd for the unit?
Also check this in the FAQ's from Rgecy....  http://forums.sideimagingsoft.com/index.php?topic=738.0
And this also...... http://forums.sideimagingsoft.com/index.php?topic=738.msg6935#msg6935
« Last Edit: April 09, 2011, 11:55:20 AM by sonar2000 »
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #2 on: April 09, 2011, 05:09:31 PM »
Hello Geggen and welcome to the forum!
Make sure you have the record view visible. Store this view on one of the three preset buttons. If you want to do a recording, just hit the preset button, press the menu button and go down the the "start recording" tab. Press the left cursor button and the recording starts. To stop the recording just hit the menu button and go down to the "stop recording" tap.
Next press the left cursor button et voilá, you're done.
To review the recording, go to the recording view, press the menu button and use the down cursor to highlight the recording. Press the menu button and choose "start review" (or something like that).
TO review the recordings on your computer I recommend to download Hummviewer from Martin here:
http://humviewer.cm-johansen.dk/
Hope this helps!
Best wishes / Harry
Hope this helps and good luck
Harry
YES,......
WE SCAN!
Last post June 28, 2012, 12:00:14 AM
by Roddy
Last post July 16, 2012, 04:19:22 PM
by catfish21
Last post November 17, 2013, 08:50:09 PM
Last post December 12, 2013, 01:52:53 PM
by jules2003
Last post August 23, 2015, 05:49:54 PM
by al49
Last post June 21, 2016, 11:33:31 AM
Last post January 19, 2017, 11:13:58 PM
Last post June 19, 2019, 08:24:48 PM
by Gimp
