Author Topic: Need to understand  (Read 8136 times)
Offline jjbch
Need to understand
« on: April 06, 2011, 07:45:58 PM »
I would like to link a 898 to a 728, by having the interlink module does that mean that the 728 will work from the 898 gps, or do i need to buy an additional antenna for the 728
Re: Need to understand
« Reply #1 on: April 07, 2011, 01:46:33 AM »
Yes, you can use the GPS thru the Interlink module to connect the 728.  You will not need any additional parts.
Offline jjbch
« Reply #2 on: April 07, 2011, 08:55:27 AM »
Thanks for the reply.  What cables would I need to get this done?
« Reply #3 on: April 07, 2011, 12:29:49 PM »
Nothing.  You should have all the cables you need to make it work (more on that below).  There are some cables that come with the InterLink that will connect to both your 898c Si unit and to the 728 unit.  You have three ways of doing this:
1.) Connect the GPS Receiver you have to the InterLink and the InterLink to each units COM connector (where the GPS Receiver plugs in).  Advantage: each unit can use the GPS Receiver without the other unit having to be powered on.  Disadvantages: neither unit will have the faster 4x GPS refresh rate and depending on where the GPS Receiver is located; the waypoints will be off for one or both units.
2.) Connect the GPS Receiver to one of the units using the AS-YC “Y”-cable that came with your 898c Si unit.  The GPS Receiver will plug into the connector labeled “NMEA-COM”, the InterLink plugs into the connector labeled “ACCY-COM” and the third plug is connected to the COM connector on the unit.  The second unit gets connected to the InterLink with the supplied cables to that unit’s COM connector.  Advantages: The unit that the GPS Receiver is connected to will have the faster 4x GPS refresh rate and will have more accurate waypoints (if the GPS Receiver is located close to the transducer that it is using).  Disadvantages: The primary unit (the one that the GPS Receiver is connected to through the Y-cable) will have to be powered on for the secondary unit to be able to use the GPS Receiver.  Only the primary unit will have the faster 4x GPS refresh rate.  The waypoints will be off for the secondary unit (Assuming that the GPS Receiver is located close to the transducer that the primary unit is using).
3.) Okay, for this you would have to purchase another GPS Receiver.  Both units have GPS Receivers connected to them through an AS-YC Y-cable and have the GPS Receivers located close to the transducers that they use.  Advantages: both units have the faster GPS refresh rate.  Both units can use GPS independently of each other.  Waypoints for both units will be more accurate.  Disadvantages: cost of the second GPS Receiver and its installation.
Offline jjbch
« Reply #4 on: April 07, 2011, 05:39:30 PM »
Thanks so much.  Gregg, I see you respond to a lot of people on all different sites.  I'm sure there are are many of us grateful for you and those like you that take the time and try to educate.  Thanks again.
Last post August 05, 2009, 03:04:43 PM
Last post March 24, 2013, 10:48:13 PM
Last post April 13, 2015, 02:06:04 PM
by johnmr12
Last post January 04, 2016, 09:13:57 PM
Last post July 30, 2019, 11:10:45 PM
