Author Topic: back up info to sd keep getting failed statement on 998  (Read 10839 times)
Offline larry e frazier
  • Unit(s): 998c 786ci2 787c2(2)
  • Software: ?
  • Accessories: Interlink between 787c2's &998/786ci2
« on: March 25, 2011, 03:16:18 AM »
Been trying to backup my waypoints to sd card everytime I try to export it comes with the message that it has failed. Am I doing something wrong I switched to both slots and still no luck.  I have a 1 mb card built in maps and I am interlinked to another chartplotter. Tried to get waypoints from the chartplotter 785ci and the same thing happened. thought it might be card but it reads fine on my home computer and HB software. Help me please!
« Last Edit: March 25, 2011, 03:17:50 AM by larry e frazier »
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: back up info to sd keep getting failed statement on 998
« Reply #1 on: March 25, 2011, 06:52:16 AM »
Unhook your  interlink and try export all navigational data. Gary
« Reply #2 on: March 25, 2011, 02:01:56 PM »
If this is a map card it may be write proptected.  If this is a standard sd card make sure the little white switch is not in the protect position.
Try Gary's idea aslo.
and let us know...
« Last Edit: March 26, 2011, 04:12:24 PM by sonar2000 »
« Reply #3 on: March 26, 2011, 01:02:33 AM »
Chuck is correct.  You do not want to export to the map card.  It could also corrupt the data on the card.
You will need a blank SD card.
« Last Edit: March 26, 2011, 04:12:02 PM by sonar2000 »
  • Software: ?
« Reply #4 on: March 29, 2011, 02:59:17 AM »
This is not a map card it is a 1 g sd that I have used to backup my waypoints in the past. In fact I down loaded  the info into another hb just before I tried to download all my info from the 998.  Why would I have to unhook the inter link?
« Reply #5 on: March 31, 2011, 05:22:33 PM »
I would try formatting the memory card and trying again.
If that does not work, try a new memory card.
Last post July 13, 2009, 11:04:22 AM
by mrj9600
Last post February 14, 2010, 04:04:22 AM
by mrj9600
Last post March 16, 2010, 11:06:45 AM
Last post February 18, 2011, 04:31:03 PM
Last post December 19, 2012, 03:39:46 PM
Last post March 29, 2013, 03:39:07 PM
Last post April 29, 2013, 03:11:51 PM
Last post May 13, 2015, 06:43:04 PM
by wconn1979
